Dear LAMMPS developers,
I have a question about the image flags of LAMMPS, and could not find the answer in the previously posted lists in the LAMMPS mailing lists.
I noticed there is clarification from Axel in the mailing lists: “IMPORTANT NOTE: The periodic image flags of atoms in rigid bodies are modified when the center-of-mass of the rigid body moves across a periodic boundary. They are not incremented/decremented as they would be for non-rigid atoms. This change does not affect dynamics, but means that any diagnostic computation based on the atomic image flag values must be adjusted accordingly. For example, the compute msd will not compute the expected mean-squared displacement for such atoms, and the image flag values written to a dump file will be different than they would be if the atoms were not in a rigid body. It also means that if you have bonds between a pair of rigid bodies and the bond straddles a periodic boundary, you cannot use the replicate command to increase the system size.”
The following is a description of my question:
I have rigid bodies in my simulation. At the end of the simulation, I generated a datafile using the “write_data” command, and a restart-file using the “write_restart” command. My Questions:
(1) Are the image flags of atoms in rigid bodies in the generated datafile different than they would be if the atoms were not in a rigid body?
(2) Can I use the generated datafile with the image flags for a next simulation with the same rigid bodies?
(3) Can I use the generated restart-file (with the “remap” flag) to continue my simulation with the same rigid bodies?
(4) If I use the generated datafile to run a simulation without rigid bodies, and generate another datafile2 at the end of the simulation, will the image flags in datafile2 be correct? Can I use datafile2 in a simulation with replicate command without worrying about the image flags?
Thank you so much!
Jibao
