In recent versions of lammps (30Oct2013) it appears that the image flags of atoms are not correctly written to restart files. I noticed this when lammps gave the "Inconsistent image flags" warning when reading a restart with bonded atoms. Inspecting the dump file (generated after read_restart) I found that all of the image flags for all atoms were -512.
I reproduced this problem using a minimal lammps script (attached) where a single atom of type atomic diffuses in a periodic box using fix nve and fix langevin. In the generated restart file the images flags are -512. This can be seen both in a dump file generated after reading the restart, and in a data file generated using the restart2data.cpp tool.
I ran the same script using an older version of lammps (21Feb13) and the image flags were correct after the restart. Is this a bug in recent versions, or am I doing something wrong?
Chris Brackley
in.script (904 Bytes)
