Implement custom force field via the FIELD keyword
Hi Evangelos,
For illustrative purposes, your original script read as follows:
#!/usr/bin/env emc_setup.pl
# Options
ITEM	OPTIONS
ntotal		1000
temperature	353.15
density		0.1
field_name      standard
field_location  .
mass		true
replace		true
build_dir	.
ITEM	END
# Shorthand
# Groups
ITEM    GROUPS
water         O
tfe           *C2(F)(F)C2(F)(F)*,1,tfe:2
htfe          *C2(F)(F)C3(F)(F)F,1,tfe:1,1,tfe:2
ITEM    END
# Clusters
ITEM    CLUSTERS
water           water,0.054523562
poly            alternate,1
ITEM    END
# Polymers
ITEM    POLYMERS
poly
100             tfe,98,htfe,2
ITEM    END
# Force Field specification according to the B3LYP/6-13G* data
ITEM    FIELD
# Definitions
ITEM    DEFINE
FFNAME  STANDARD
FFTYPE  ATOMISTIC
LENGTH  ANGSTROM
ENERGY  KCAL/MOL
DENSITY G/CC
MIX     BERTHELOT
CUTOFF  9.5
NBONDED 2
ANGLE   COMPLETE
TORSION COMPLETE
ITEM    END
# Masses
ITEM    MASS
# type  mass    element ncons   charge  comment
C2      12.011  C       4       0.378   C atom for -CF2-
C3      12.011  C       4       0.567   C atom for -CFE
F       18.998  F       1       -0.189  F atom
O       15.9994 O       2       -0.8476 O atom for water
H       1.00790 H       1       0.4238  H atom for water
ITEM    END
# Nonbond parameters
ITEM    NONBOND
# type1 type2   sigma   eps
F       F       2.94    0.061
C2      F2      3.50    0.066
C3      F3      3.50    0.066
O       O       3.16556 0.15539
H       H       1.0     0.0
ITEM    END
# Bond parameters
ITEM    BOND
# type1 type2   k       l0
C2      C2      259.93  1.54
C2      C3      259.93  1.54
F       C2      304.82  1.38
F       C3      304.82  1.38
O       H       600.00  1.00
ITEM    END
# Angle parameters
ITEM    ANGLE
# type1 type2   type3   k       theta0
F       C2      F       107.64  108.72
F       C3      F       107.64  108.72
F       C2      C2      56.39   107.90
F       C2      C3      56.39   107.90
F       C3      C2      56.39   107.90
F       C3      C3      56.39   107.90
C2      C2      C2      56.39   107.90
C2      C2      C3      56.39   107.90
C2      C3      C2      56.39   107.90
C2      C3      C3      56.39   107.90
C3      C2      C3      56.39   107.90
C3      C3      C3      56.39   107.90
H       O       H       75.00   109.47
ITEM    END
# Torsion parameters
ITEM    TORSION
# type1 type2   type3   type3   k       n       delta   [...]
F       C2      C2      F       1       1       1
F       C2      C3      F       1       1       1
*       *       *       *       1       1       1
ITEM    END
ITEM    END     # FIELD
As a general remark: this script mainly contains spaces as separating characters. EMC Setup and derived modules function better when you use TABs.
Regarding your error: in general, the error occurs when a ring closure cannot be found, as is the case for the cyclodextrin question on this board. Specifically, your error has to do with how you defined your SMILES under ITEM GROUPS. You defined your tfe group with tfe *C2(F)(F)C(F)(F)*. You provided an opening link in your SMILES by providing a 2, but you never provided the accompanying closing link, hence the error. If you would have wanted not to use rules, you could have defined this group by using your types: the *[c2](f)(f)c(f)(f). Note that the field module converts used types to lower case.
Regarding using ITEM FIELD: EMC comes with an included example in $EMC_ROOT/examples/setup/chemistry/field/user, where a user defined polymer force field is used. EMC Setup uses a force field module to obtain your standard.prm and standard.top. Be aware, that this force field requires a TAB to be the separator between fields. Using spaces will cause the module to function incorrectly. Both parameters and rules can be included in the ITEM FIELD section. I included partial wild cards for your parameters. With these changes, your script looks as follows:
# Options section
ITEM	OPTIONS
ntotal		1000
temperature	353.15
density		1.0
field_name	standard
field_location	.
field_format	%g
mass		true
replace		true
build_dir	.
emc_execute	true
ITEM	END	# OPTIONS
# Groups section
ITEM	GROUPS
water		O
tfe		*C(F)(F)C(F)(F)*,1,tfe:2
htfe		*C(F)(F)C(F)(F)F,1,tfe:1,1,tfe:2
ITEM	END	# GROUPS
# Clusters section
ITEM	CLUSTERS
poly		alternate,1
ITEM	END	# CLUSTERS
# Polymers section
ITEM	POLYMERS
poly
100		tfe,98,htfe,2
ITEM	END	# POLYMERS
ITEM	FIELD
# Definitions
ITEM	DEFINE
FFNAME		STANDARD
FFTYPE		ATOMISTIC
FFDEPTH		2
LENGTH		ANGSTROM
ENERGY		KCAL/MOL
DENSITY 	G/CC
MIX		BERTHELOT
CUTOFF		9.5
NBONDED 	2
ANGLE		ERROR
TORSION 	ERROR
ITEM	END
# Masses
ITEM	MASS
c2	12.011	C	4	0	C atom for -CF2-
c3	12.011	C	4	0	C atom for -CFE
f	18.998	F	1	0	F atom
o	15.9994	O	2	0	O atom for water
h	1.00790	H	1	0	H atom for water
ITEM	END
# Rule precedences
ITEM	PRECEDENCE
  (c2)
  (c3)
  (f)
  (o)
  (h)
ITEM	END
# Rules
ITEM	RULES
# type	charge	rule
c2	0.378	C(F)(F)(C)(C)
c3	0.567	C(F)(F)(F)(C)
f	-0.189	F(C)
o	-0.8476	[O](H)(H)
h	0.4238	H(O(H))
ITEM	END
ITEM	NONBOND
f	f	2.94	0.061
c2	c2	3.50	0.066
c3	c3	3.50	0.066
o	o	3.16556	0.15539
h	h	1.0	0.0
ITEM	END
# Bond parameters
ITEM	BOND
# type1 type2	k	l0
c*	c*	259.93	1.54
f	c*	304.82	1.38
o	h	600.00	1.00
ITEM	END
# Angle parameters
ITEM	ANGLE
f	c*	f	107.64	108.72
*	c*	c*	56.39	107.90
h	o	h	75.00	109.47
ITEM	END
ITEM	TORSION
f	c*	c*	f	1	1	1
*	*	*	*	1	1	1
ITEM	END
ITEM	END	# FIELD
I added ffdepth 2 since your rules have a maximum recursion depth of 2 (see your rules for water oxygen and hydrogen). I added field_format %g to change the numerical format of the resulting force field files. For completeness sake, I also attached the resulting script.
standard.esh (1.8 KB)
