Implement Rotating Wall
Hey Steve
Following up for my previous question.
The set up I was aiming for was a vertical cylinder of particles within a vertical cylinder which rotates. So then unfix the vertical cylinder of particles so they freely collapse. Would the following way work for this setup…
  1. create a cylinder region named tank and set the entire region to rotate
  2. fix zplane (bottom of cylinder) so it is treated as a wall, and can set various parameters
  3. create a new cylinder region named column within tank and fill with particles
  4. Unfix column so the particles begin to flow
If this is not the way, I am a little bit at a loss at how to edit the fix_wall_gran.cpp to allow this. I see the lines
void FixWallGran::post_force(int vflag)
double vwall[3],dx,dy,dz,del1,del2,delxy,delr,rsq;
// set position of wall to initial settings and velocity to 0.0
// if wiggle or shear, set wall position and velocity accordingly
double wlo = lo;
double whi = hi;
vwall[0] = vwall[1] = vwall[2] = 0.0;
if (wiggle) {
double arg = omega * (update->ntimestep - time_origin) * dt;
if (wallstyle == axis) {
wlo = lo + amplitude - amplitude*cos(arg);
whi = hi + amplitude - amplitude*cos(arg);
vwall[axis] = amplitudeomegasin(arg);
} else if (wshear) vwall[axis] = vshear;
which would be the main part of the file I need to edit (I know there would be other minor additions over the code), but am at a bit of a loss as you appear to only edit velocities in this file.
Am I going down the wrong road??
Cheers
Jay
The problem with your 1st 4 steps is there is no fix wall/region/gran
command. I.e. the rotating region will not interact with granular
particles in a granular manner. So something like the edits
you proposed to the fix wall/gran code would need to be done.
