Hi all,
I want to simulation a Cu nanoparticle between two Fe blocks, while the blocks are imposed a Vx velocity and a F(z) force.
The expected result is sliding block, but no movement happen in the model except atom vibrations at their place.
I would appreciate if you let me know what is wrong in my code.
image of the model and code are attached
I’m using LAMMPS 64X 20170127, MPI runnig on windows
