I have been trying to determine the exact procedure used in improper angle calculation in LAMMPS.
I have picked up a part of the code from compute_improper_local.cpp and have tried to figure out what happens - step by step
vb1x = x[atom1][0] - x[atom2][0];
vb1y = x[atom1][1] - x[atom2][1];
vb1z = x[atom1][2] - x[atom2][2];
domain->minimum_image(vb1x,vb1y,vb1z);
~~ vb1 = coordinates(1) - coordinates(2)
vb2x = x[atom3][0] - x[atom2][0];
vb2y = x[atom3][1] - x[atom2][1];
vb2z = x[atom3][2] - x[atom2][2];
domain->minimum_image(vb2x,vb2y,vb2z);
~~ vb2 = coordinates(3) - coordinates(2)
vb3x = x[atom4][0] - x[atom3][0];
vb3y = x[atom4][1] - x[atom3][1];
vb3z = x[atom4][2] - x[atom3][2];
domain->minimum_image(vb3x,vb3y,vb3z);
~~ vb3 = coordinates(4) - coordinates(3)
I am correct in assuming that the improper angle should be the angle between the planes of (vb1,vb2) and (vb2,vb3) ??
ss1 = 1.0 / (vb1xvb1x + vb1yvb1y + vb1zvb1z);
ss2 = 1.0 / (vb2xvb2x + vb2yvb2y + vb2zvb2z);
ss3 = 1.0 / (vb3xvb3x + vb3yvb3y + vb3z*vb3z);
~~ Inverse norm_squared
r1 = sqrt(ss1);
r2 = sqrt(ss2);
r3 = sqrt(ss3);
~~ Inverse norm of the angles
c0 = (vb1x * vb3x + vb1y * vb3y + vb1z * vb3z) * r1 * r3;
~~ cosine of angle between vb1 and vb3? (say) alpha
c1 = (vb1x * vb2x + vb1y * vb2y + vb1z * vb2z) * r1 * r2;
~~ cosine of angle between vb2 and vb1? (say) beta
c2 = -(vb3x * vb2x + vb3y * vb2y + vb3z * vb2z) * r3 * r2;
~~ negative cosine of angle between vb2 and vb3? (say) gamma
s1 = 1.0 - c1*c1; ~~ sin^2 of vb2 and vb1?
if (s1 < SMALL) s1 = SMALL;
s1 = 1.0 / s1;
s2 = 1.0 - c2*c2; ~~ sin^2 of vb2 and vb3?
if (s2 < SMALL) s2 = SMALL;
s2 = 1.0 / s2;
s12 = sqrt(s1s2); ~~ 1/sin(angle vb2 and vb1) * 1/sin(angle vb2 and vb3)
c = (c1c2 + c0) * s12;
~~ IS c = [ 1-* cos(alpha)*cos(beta) + cos(gamma))/ sin(alpha)/sin(beta) ]??
if (c > 1.0) c = 1.0;
if (c < -1.0) c = -1.0;
cbuf[n] = 180.0*acos©/MY_PI;
Question 1:
I do not understand how cos_inverse of ‘c’ should be the angle between the two planes? Is there a geometric explanation that I should look at?
Question 2:
Also, while specifying the improper angles in the input files as ( i j k l ) should give the same magnitude for the improper angle as ( l j k i ) . Is that right?
Question 3:
Finally, for improper style harmonic and cvff does lammps explicitly calculate the displacement of atom “i” from the plane j-k-l? My understanding is that it just calculates the angle between the ijk and jkl planes.
Thank you,
Regards,
Ambarish
