Incidentally, on Feb 28th, John Jasa posted a notice saying he saw
some evidence of numerical problems using "improper class2". I don't
know if it's true, and I'm not trying to defame "class2". The example
he posted does not conserve energy, however this could happen if he
did not set the timestep carefully (In fact, it does not seem like he
set the timestep. I did not have time to look into this.) Anyway,
I'm curious to know if there is in fact a problem with "improper
class2".
I have included his example (see attachments), and forwarded his post
below. (For some reason I can't find it on the mail list archives.)
Cheers
Andrew
-------------John Jasa 's post from 2013-3-4 -------------------
Hi there,
Thanks much for the help! Going through your steps, I got this output
for NVE for the simple system with only pair and a single improper:
Step Temp E_pair E_mol TotEng Press Volume
0 75.318871 -0.0053814401 -1157.3088 -1156.6407
15.409808 9856.1106
1000 1203.1993 -0.050567446 -1141.1285 -1130.4195
66.081203 11749.538
2000 3280.8694 0 -1146.7563 -1117.4174
22.308446 67552.829
3000 3381.1489 0 -1143.8259 -1113.5902
5.6520083 274604.02
4000 3872.6671 0 -1152.4135 -1117.7824
2.5031675 676718.7
5000 4235.652 0 -1156.9435 -1119.0665
1.1762173 1562098.8
6000 3785.9493 0 -1152.8176 -1118.962
0.54918059 2999107.4
7000 3757.9019 0 -1152.2252 -1118.6204
0.3276495 5105683.9
8000 4060.3406 0 -1155.1911 -1118.8817
0.21769128 8038926.2
9000 4089.5768 0 -1155.6786 -1119.1078
0.14488222 11884200
10000 4402.8871 0 -1158.612 -1119.2395
0.10896606 16853927
So the total energy appears to start at -1156.6407 then come to rest
around a value of -1119.2395. This is with arbitrarily chosen
coefficients for each of the relations.
Changing the value of chi0 to 0 yielded:
0 253.32252 -0.022262517 -1593.7227 -1591.4796
5.8869811 237953.25
1000 3431.7074 0 -1597.3416 -1566.6538
4.6246316 309276.67
2000 3164.4039 -0.0045368486 -1595.3152 -1567.0223
3.222129 405380.67
3000 3151.1313 0 -1596.2679 -1568.0891
1.8733732 693272.88
4000 3305.3063 0 -1590.8601 -1561.3027
1.1017327 1226781.4
5000 3728.5643 0 -1598.1024 -1564.7599
0.71864144 2126120.3
6000 3462.4435 0 -1592.3131 -1561.3504
0.40161397 3574892.5
7000 3500.4681 0 -1592.7041 -1561.4014
0.23239199 6239732.8
8000 3913.3955 0 -1597.0418 -1562.0465
0.17765942 9044915.8
9000 3696.002 0 -1594.767 -1561.7158
0.11508685 13520692
10000 3931.9689 0 -1596.6941 -1561.5327
0.085038176 19220146
Again, the total energy starts at a certain amount (-1591.4796) before
leveling off around -1561.
Yes, the atoms are well within the boundaries of the system, however
for this simple test case I'm using shrink-wrapped non-periodic
boundaries to validate the forces felt by only the atoms in one image.
Should I only use periodic boundary conditions in this case?
I sent my code and the source code to a colleague so hopefully another
pair of eyes can help shed light on possible discrepancies or errors.
Attached are the files used for the force investigation.
Thanks again,
John Jasa
in.TinyForce (402 Bytes)
TinyForce.data (741 Bytes)
