Incorrect args for pair coefficients (src/pair_morse.cpp:182) in "pair_style hybrid"
When I try to use the hybrid form to describe Cu(eam/alloy), TiC(meam) and the force (morse) between the two interfaces, I get ERROR: Incorrect args for pair coefficients (src/pair_morse.cpp:182). I don’t know how to fix this error.
Below are my hybrid settings and errors:
pair_style hybrid eam/alloy meam morse 2.95
pair_coeff * * meam library_TiC.meam Ti C TiC.meam Ti C NULL
Reading MEAM library file library_TiC.meam with DATE: 2015-02-12
pair_coeff * * eam/alloy Cu_zhou.eam.alloy NULL NULL Cu
Reading eam/alloy potential file Cu_zhou.eam.alloy with DATE: 2007-10-12
pair_coeff * * morse 71.392 3.272 2.59 Ti NULL Cu
Last command: pair_coeff * * morse 71.392 3.272 2.59 Ti NULL Cu
Your pair_coeff for the Morse potential does not follow the documentation. Could it be the problem?
thank you for your reply
yes, When I modify to the following format it works fine:
pair_style hybrid eam/alloy meam morse 7.375|
pair_coeff 1 3 morse 71.392 3.272 2.59
pair_coeff 2 3 morse 71.392 3.272 2.59 7.475
