Incorrect atom format in data file (../atom.cpp:778)
Hello everyone,
I am trying to simulate a very simple system. I set the atom_style atomic and I provided a data file containing the required quantities. however, when I run the code it says “Incorrect atom format in data file (…/atom.cpp:778)”. I made the system as simple as possible and also tested it with other data but I could not find the reason.
here are some of the first lines of my input file:
input file to generate a liquid-glass systems
echo both
units lj
processors * * *
#read data
atom_style atomic
read_data glass.data
and here are the quantities in the data file:
400 atoms
2 atom types
0 6.9336 xlo xhi
0 6.9336 ylo yhi
0 6.9336 zlo zhi
Masses
1 1 # A
2 1 # B
Atoms
1 1 4.643 6.5332 0.6658
2 1 0.41497 5.8896 1.3825
3 1 2.6644 0.95187 4.2091
4 2 3.406 4.5812 4.9209
5 1 5.3677 0.26687 6.1746
6 2 1.0249 1.0273 4.1785
7 1 3.3665 1.2811 5.9799
8 1 0.49808 4.4747 4.6868
I would be thankful if you help me.
What is your LAMMPS version?
Please provide a complete data file, best one with fewer atoms.
thank you for your reply
It is LAMMPS 64-bit 20140528. I have no idea if it is acceptable for my work or not.
here is the complete data file. I have set it for 10 particles.
#Initial Configuration of a liquid. LAMMPS data file.
10 atoms
2 atom types
0 6.9336 xlo xhi
0 6.9336 ylo yhi
0 6.9336 zlo zhi
Masses
1 1 # A
2 1 # B
Atoms
4 1 3.406 4.5812 4.9209
6 1 1.0249 1.0273 4.1785
9 2 5.4598 5.939 5.4429
10 2 2.73 5.917 3.7209
I tested the code even for a one-particle system and still I get the same error.
Fatima
Your LAMMPS version is nearly six years old. You should try a more recent version. There have been lots of improvements to LAMMPS since your current version including better error messages and a less strict parser for data files.
ok, I will do that. thank you.
