Dear lammps users,
I want to perform an energy minimization on my structure with UFF force field. I have prepared my data file in which the dihedral section is as follow:
Dihedral Coeffs # harmonic
1 0.000000 0 0 # O_R-Cr6+3-O_R-C_R
2 0.000000 0 0 # O_2-Cr6+3-O_R-C_R
3 0.000000 0 0 # O_R-Cr6+3-O_2-Cr6+3
4 2.245703 -1 2 # Cr6+3-O_R-C_R-O_R
5 0.000000 0 0 # Cr6+3-O_R-C_R-C_R **
6 0.000000 0 0 # F_-Cr6+3-O_R-C_R
7 0.000000 0 0 # H_-C_R-C_R-H_**
8 1.497136 -1 2 # C_R-C_R-C_R-H_
9 0.000000 0 0 # C_R-C_R-C_R-C_R **
10 0.555556 -1 2 # O_R-C_R-C_R-C_R
11 0.000000 0 0 # F_-Cr6+3-O_2-Cr6+3
I could not find UFF parameters for the lines specified by stars.
when I run my code, I face this error:
ERROR: Incorrect sign arg for dihedral coefficients (…/dihedral_harmonic.cpp:290).
I changed the sign of 1 in dihedrals but it does not work. I don not know what the problem is. Any help will be appreciated.
Regards,
Mina
Dear lammps users,
which is really, really bad. you cannot expect reasonable results,
when part of your interactions is missing.
ERROR: Incorrect sign arg for dihedral coefficients (../dihedral_harmonic.cpp:290).
please look at the documenation! it clearly says, that the parameter
"d" must be either "1" or "-1".
if you use a recent enough version of LAMMPS it should tell you which
line exactly this refers to.
...and if you look at the formula, you should realize, that a value of
0 for "d" makes no sense whatsoever in the first place.
all of these terms have a force constant of zero, so it doesn't really
matter what kind of values you enter for those those are contributing
not forces.
