I am trying to simulate a molecule under quasistatic tensile loading (to stretch it by pulling at one end), whereby load steps are applied incrementally using minimize.
Therefore, I fix an atom at one end using setforce and apply a constant force to an atom at the other end using addforce.
My script for this is very short and attached below, in which I am only finding the configuration of minimum potential energy using minimize and then trying to apply one load step using minimize.
However, I do not see any changes in the configuration after the last minimization, e.g., the applied force does not seem to have any effect… different values for the force constant and minimization tolerances also did not change anything.
My apologies in advance if I am overlooking something very simple!
(I am using LAMMPS 32-bit 20150121)
Many thanks in advance,
Mia
