input cause MPI error
Dear Users,
I can run some stuff on MPI and is succeed.However,It occurs some MPI errors when I using the input below.Could you please let me know,which command might be cause this MPI problem?For my previous succeed stuff.I didn’t use the commands as I marked in red color with below input.
Thank you very much for your time in advance.
Errors
[marge11:40473] *** An error occurred in MPI_Allreduce
[marge11:40473] *** on communicator MPI_COMM_WORLD
[marge11:40473] *** MPI_ERR_TRUNCATE: message truncated
[marge11:40473] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
Dear Users,
didn't use the commands as I marked in red color with below input.
​there is not enough information here to give any recommendations. while
this may be triggered by the commands you highlight, this kind of MPI error
usually originates from some *other* command causing stray MPI messages.
you need to report which LAMMPS version you are using and on what platform
you are running and provide a *complete* input deck and the exact command
line, that you are using, so that somebody else can investigate and try to
reproduce the failure you are seeing.
axel.​
Dear User,
Thank you very much for your suggestions.
The problem I was facing has been fixed after installing newest lammps version.Newest lammps will not face this problem.
Thank you
All Best
Liyi Bai
发自网易邮箱大师
