I am writing a LAMMPS input script for a dense polymeric system. So I am using the nve\limit command to limit the maximum amount my atoms can travel in a timestep, so that they do not fly across the simulation box. Over time, I want to increase the maximum distance they can travel in a time step (increment the nve\limit fix) so that my system can reach equilibrium. Do you think that the following script will work? I have tried some diagnostics on it, and it seems to work, but I would like to make sure. I unfix the old nve limit and put in a new one, and then I use the run upto ___ command to tell it how many timesteps to run with the new nve limit fix, until I delete it and put in a new one that increments the maximum amount the atoms are allowed to move, and then put in another run upto command, all until my simulation is over. Every million timesteps I unfix the old nve/limit and put in a new one, and run upto another million timesteps. Do you think that I should use the run start/stop command instead of the run upto command, or will this work fine for my purposes?
Thank you,
Here is the script:
units lj
atom_style molecular
read_data data12424.1.000000
pair_style lj/cut 2.5
pair_coeff * * 1.000000 1.000000
bond_style fene
special_bonds fene dihedral no
bond_coeff * 30.000000 1.500000 1.000000 1.000000
fix 1 all nve/limit 0.100000
fix 2 all langevin 1.000000 1.000000 1 48279
timestep 0.005000
dump MyDump all custom 1000 dump12424.1.000000.txt id x y z
run 1000000 upto
unfix 1
fix 1 all nve/limit 0.200000
run 2000000 upto
unfix 1
fix 1 all nve/limit 0.300000
run 3000000 upto
unfix 1
fix 1 all nve/limit 0.400000
run 4000000 upto
unfix 1
fix 1 all nve/limit 0.500000
run 5000000 upto
unfix 1
fix 1 all nve/limit 0.600000
run 6000000 upto
unfix 1
fix 1 all nve/limit 0.700000
run 7000000 upto
unfix 1
fix 1 all nve/limit 0.800000
run 8000000 upto
unfix 1
fix 1 all nve/limit 0.900000
run 9000000 upto
unfix 1
fix 1 all nve/limit 1.000000
run 10000000 upto
unfix 1
fix 1 all nve
run upto 1000000000
