Dear Lammps Users,
I am working on a system including two Platinum plates (you can find my system’s configuration in attachment). I am going to freeze the outer most layer in each plate. To do so as you can see in my input file I am using fix setforce 0 0 0. Besides, I want to equilibrate the whole system at 300K using Brendsen thermostat. To record the temperature evaluation, I defined a compute temp for each plate. In addition, I thought because I am fixing one layer( including 1352 atoms) in each plate, I must exclude those DOFs (3*1352) from compute temp. The thing is, as you can see in my log file, the temperature in the plates at the end of equilibration are almost 50 K higher than the value that I specified. I doubt that maybe I am not using compute_modify command in a correct way!!
I will be very thankful if someone could tell me what I am doing wrong here.
----------------------------------------------------------------------------- Input file----------------------
units real
atom_style atomic
lattice fcc 3.92
region whole block 0 100 0 120 0 100 units box
create_box 2 whole
region Pt_B block 0 100 0 6 0 100 units box #Bottom Wall
region Pt_T block 0 100.0 109 120 0 100 units box #Top wall
region Pt_B_fix block INF INF INF 1.5 INF INF units box
region Pt_T_fix block INF INF 118 INF INF INF units box
mass 1 195.1
mass 2 39.95
create_atoms 1 region Pt_B
create_atoms 1 region Pt_T
group whole region whole
group PtB region Pt_B
group PtT region Pt_T
group PtBfix region Pt_B_fix
group PtTfix region Pt_T_fix
group PtB_thermo subtract PtB PtBfix
group PtT_thermo subtract PtT PtTfix
timestep 1
#----------------------------------------------FORCE FIELD--------------------------------------------------------------
pair_style lj/cut 8.5
pair_coeff 1 1 7.49504 2.47
pair_coeff 1 2 {eps_pt_Ar} {sigma_pt_Ar}
pair_coeff 2 2 {eps_Ar_Ar} {sigma_Ar_Ar}
neighbor 2 bin
#---------------------------------------------DEFINING TEMP COMPUTE
compute TPtB PtB temp
compute_modify TPtB extra/dof 4056
compute TPtBthermo PtB_thermo temp
compute TPtT PtT temp
compute_modify TPtT extra/dof 4056
variable Etot equal “etotal”
thermo 1000
thermo_style custom step c_TPtB c_TPtT ke pe etotal
thermo_modify lost warn
#####-----------------------------------------------------------Energy minimization
min_style cg
minimize 1e-16 1e-16 100000 100000
reset_timestep 0
timestep 1
#--------------------------------------------------------------------fixing atoms
fix 2 PtBfix setforce 0 0 0
fix 3 PtTfix setforce 0 0 0
#---------------------------------------------Thermostating
fix 5 PtB nve
fix 6 PtB temp/berendsen 300 300 100.0
fix 7 PtT nve
fix 8 PtT temp/berendsen 300 300 100.0
run 1000000
