Inquiry on RDF: Selecting Group-ID
Dear Dr. Axel Kohlmeyer,
Hello Dr. Kohlmeyer. I deeply appreciate your many advices on my inquiries to LAMMPS.
I would like to ask a question on compute rdf in LAMMPS.
I have a system 100 atoms in my simulation box where I have 40 Type 1 atoms and 60 Type 2 atoms interacting via LJ potential.
I wanted to see how the Type 2 atoms are distributed with respect to Type 1 atoms. I named by Type 1 atoms as “PN” and my Type 2 atoms as “SN.” Therefore, I included the following command:
compute myRDF all rdf 200 1 2 cutoff 5.0
According to the documentation, if I specified “all” as the group-ID, then the radial distribution function will be normalized with the bulk density of the entire system.
However, when I specified the “PN” as the group-ID, I was curious if the bulk density will only consist of the Type 2 atoms as if the following:
compute myRDF PN rdf 200 1 2 cutoff 5.0
I compared my simulation result between using these two commands, and I obtained exact same RDF for the two cases, one that considers all atoms and other that considers only Type 1 atoms.
I was curious if there are ways to have the radial distribution function only compute the bulk density of the specific types of atoms desired. Thank you.
Sincerely,
Masato Koizumi
compute 1 fluid rdf 500 1 1 1 2 2 1 2 2
Hello Dr. Kohlmeyer. I apologize that my previous message was confusing.
I would like to ask if the group-ID in the compute rdf command has any contributions to the radial distribution calculations.
That is, since radial distribution function is local density divided by the particle (bulk) number density, and if I specified:
I understand that the local density will be divided by the particle density of the entire system for “all” atom types available in the system.
Meanwhile, if I specified:
compute myRDF SN rdf 200 1 2 cutoff 5.0,
and SN refers to only the Type 2 atoms contained in my entire system, I was curious if the local density will be divided by the particle density of ONLY SN atoms, NOT the entire system consisting all atoms types.
I tried these two cases, and I obtained the exact same RDF curves. I was curious if there are anyways that I can have control of dividing the local density with respect to the specific particle density of the system based on the type of atoms I specified.
Thank you so much for your time.
Sincerely,
Masato Koizumi
