Hi Lammps people!
I try appml / clMath (clFft) compiled Lammps, but after I added the
appropriate environment make linux given, it should be about changing the
FFTW result. I would like to ask you, whether by replacing the FFTW
library that implements the AMD GPU computing.
lammps version lammps-30Oct13
libclFFT.so.2.1.0==>libfftw.so
clAmdFft.h==>fftw.h
Makefile
CC = mpicc
CCFLAGS = -O
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = mpicc
LINKFLAGS = -O
LIB = -lstdc++
SIZE = size
ARCHIVE = ar
ARFLAGS = -rc
SHLIBFLAGS = -shared
LMP_INC = -DLAMMPS_GZIP -DLAMMPS_JPEG
MPI_INC = -DMPICH_SKIP_MPICXX
MPI_PATH =
MPI_LIB = -lmpich -lmpl -lpthread
FFT_INC = -DFFT_FFTW
-I/home/zpg/Downloads/clFFT-develop/src/include/ -I/opt/AMDAPP/include/
FFT_PATH =
FFT_LIB = /home/zpg/Downloads/clFFT-develop/src/library/libfftw.so
Error message��
mpicc -O -DLAMMPS_GZIP -DLAMMPS_JPEG -DMPICH_SKIP_MPICXX -DFFT_FFTW
-c ../ewald_disp.cpp
-c ../fft3d.cpp
In file included from ../fft3d.cpp:25:
../fft3d.h:214: ����FFTW_COMPLEX��û������һ������
../fft3d.h:250: ����ISO C++ ���������������͵ġ�FFT_DATA��
../fft3d.h:250: ����expected ��;�� before ��*�� token
../fft3d.h:251: ����ISO C++ ���������������͵ġ�FFT_DATA��
../fft3d.h:251: ����expected ��;�� before ��*�� token
../fft3d.h:292: ����fftw_plan��û������һ������
../fft3d.h:293: ����fftw_plan��û������һ������
../fft3d.h:294: ����fftw_plan��û������һ������
../fft3d.h:295: ����fftw_plan��û������һ������
../fft3d.h:296: ����fftw_plan��û������һ������
../fft3d.h:297: ����fftw_plan��û������һ������
../fft3d.h:318: ���������ֶΡ�fft_3d������Ϊ void
../fft3d.h:318: ����FFT_DATA���ڴ�����������δ����
../fft3d.h:318: ����expected primary-expression before ��,�� token
../fft3d.h:318: ����expected primary-expression before ��int��
../fft3d.h:318: ����expected primary-expression before ��struct��
../fft3d.h:326: ���������ֶΡ�fft_1d_only������Ϊ void
../fft3d.h:326: ����FFT_DATA���ڴ�����������δ����
../fft3d.h:326: ����expected primary-expression before ��,�� token
../fft3d.h:326: ����expected primary-expression before ��int��
../fft3d.h:326: ����expected primary-expression before ��struct��
../fft3d.cpp:66: ���������ֶΡ�fft_3d������Ϊ void
../fft3d.cpp:66: ����FFT_DATA���ڴ�����������δ����
../fft3d.cpp:66: ����in���ڴ�����������δ����
../fft3d.cpp:66: ����out���ڴ�����������δ����
../fft3d.cpp:66: ����expected primary-expression before ��int��
../fft3d.cpp:66: ����expected primary-expression before ��struct�� make[1]:
*** [fft3d.o] ���� 1
make[1]: Leaving directory
`/home/zpg/Downloads/lammps-30Oct13/src/Obj_linux' make: *** [linux] ���� 2
