hi axel
i use the command you send me even i try to install again but not helpful..
i get out this error when i use sudo make linux:
Makefile: 40: write_restart .d: no such file or directory
make[1]: *** no rule to make target 'write_restard.d'. stop
make[1]: leavig directory '/home/mohamad/Desktop/lammps/src/obj-limux
make: ***[linux] error 2
how i can solve this error?
hi axel
...and i explicitly told you to *not* do this.
delete everything. and start all over from scratch. and follow the
instructions in the LAMMPS manual properly. it contains everything
that one needs to know.
failing that, you should either install the precompiled package or get
proper training in compiling in linux.
i don't have time for that and your problems are not due to LAMMPS but
due to your lack of linux compiling experience.
