Hi, LAMMPS users and developers,
I am trying to build LAMMPS with make. The version is 3-Mar-20. I follow the instruction to install USER-OMP package and other packages I need. Then, I typed “make ps” to check the status of all packages. It gives a lot of errors shown below:
Installed YES: package USER-OMP
src/angle_cosine_shift_exp_omp.cpp does not exist
src/angle_cosine_shift_omp.cpp does not exist
src/angle_dipole_omp.cpp does not exist
src/angle_fourier_omp.cpp does not exist
… and so on
There are a lot of files missing which are actually located in the subfolder “USER-OMP.” Besides, I also looked for a solution on mail list archives. I found someone has a similar problem. ( Please refer to the link: https://lammps.sandia.gov/threads/msg78017.html ) Can you please help with this problem? Any comments or suggestions will be greatly appreciated!
Best
Jonas
