Hi all,
I just run a very simple simulation, with 27 water molecules. It gives the error: Insufficient Jacobi rotations for rigid body. I have no idea how to solve this problem. Thanks for your time and help!
Regards,
Joy
Here is the In file:
units real
atom_style full
read_data data.water
velocity all create 300 432567 dist uniform
group water molecule <> 1 27
pair_style lj/cut/coul/long 10.0
kspace_style ewald 1.0e-4
pair_coeff 1 1 0.2106 3.166
pair_coeff * 2 0.0000 0.0000
pair_coeff * 3 0.0000 0.0000
fix 1 water rigid/nvt molecule temp 300.0 300.0 100.0
fix 2 all temp/rescale 50 300 300 50 1.0
neighbor 2.0 bin
neigh_modify exclude type 1 2
neigh_modify exclude type 1 3
neigh_modify delay 0 every 1 one 2000 page 20000
timestep 0.1
thermo_style custom step temp epair ebond eangle vol
thermo 500
dump myDump all xyz 1000 dump.dat
run 50000
write_restart water.restart
And data file:
LAMMPS Atom File
108 atoms
0 bonds
0 angles
0 dihedrals
0 impropers
3 atom types
0 bond types
0 angle types
-4.72 4.72 xlo xhi
-4.72 4.72 ylo yhi
-4.72 4.72 zlo zhi
Masses
1 15.9994
2 1.008
3 1e-10
Atoms
1 1 1 0.000 -3.147 -3.147 -3.147
2 1 2 0.410 -2.458 -3.057 -3.806
3 1 2 0.410 -2.684 -3.112 -2.310
4 1 3 -0.820 -2.992 -3.130 -3.123
5 2 1 0.000 -0.000 -3.147 -3.147
6 2 2 0.410 -0.183 -2.581 -3.897
7 2 2 0.410 0.928 -3.006 -2.961
8 2 3 -0.820 0.100 -3.052 -3.223
9 3 1 0.000 3.147 -3.147 -3.147
10 3 2 0.410 3.810 -2.980 -3.816
11 3 2 0.410 3.647 -3.398 -2.370
12 3 3 -0.820 3.303 -3.158 -3.132
13 4 1 0.000 -3.147 -0.000 -3.147
14 4 2 0.410 -2.717 0.604 -3.752
15 4 2 0.410 -2.748 0.188 -2.297
16 4 3 -0.820 -3.035 0.107 -3.114
17 5 1 0.000 -0.000 -0.000 -3.147
18 5 2 0.410 0.536 -0.165 -3.923
19 5 2 0.410 0.570 -0.222 -2.410
20 5 3 -0.820 0.149 -0.052 -3.152
21 6 1 0.000 3.147 -0.000 -3.147
22 6 2 0.410 3.332 0.508 -3.936
23 6 2 0.410 3.310 -0.908 -3.402
24 6 3 -0.820 3.194 -0.054 -3.287
25 7 1 0.000 -3.147 3.147 -3.147
26 7 2 0.410 -2.554 3.382 -3.860
27 7 2 0.410 -2.724 3.492 -2.360
28 7 3 -0.820 -3.010 3.225 -3.137
29 8 1 0.000 -0.000 3.147 -3.147
30 8 2 0.410 0.413 3.812 -3.698
31 8 2 0.410 0.412 3.256 -2.290
32 8 3 -0.820 0.111 3.251 -3.106
33 9 1 0.000 3.147 3.147 -3.147
34 9 2 0.410 4.057 3.217 -3.434
35 9 2 0.410 3.155 3.463 -2.243
36 9 3 -0.820 3.270 3.199 -3.064
37 10 1 0.000 -3.147 -3.147 -0.000
38 10 2 0.410 -3.078 -2.614 -0.792
39 10 2 0.410 -2.371 -2.917 0.512
40 10 3 -0.820 -3.033 -3.044 -0.038
41 11 1 0.000 -0.000 -3.147 -0.000
42 11 2 0.410 0.509 -2.535 -0.532
43 11 2 0.410 0.202 -2.904 0.904
44 11 3 -0.820 0.096 -3.032 0.050
45 12 1 0.000 3.147 -3.147 -0.000
46 12 2 0.410 3.279 -3.086 -0.946
47 12 2 0.410 3.722 -3.860 0.277
48 12 3 -0.820 3.242 -3.234 -0.090
49 13 1 0.000 -3.147 -0.000 -0.000
50 13 2 0.410 -2.542 0.132 -0.730
51 13 2 0.410 -2.582 -0.068 0.770
52 13 3 -0.820 -2.989 0.009 0.005
53 14 1 0.000 -0.000 -0.000 -0.000
54 14 2 0.410 0.467 -0.420 -0.723
55 14 2 0.410 0.125 -0.592 0.742
56 14 3 -0.820 0.080 -0.136 0.003
57 15 1 0.000 3.147 -0.000 -0.000
58 15 2 0.410 3.669 0.489 -0.636
59 15 2 0.410 3.627 -0.819 0.126
60 15 3 -0.820 3.282 -0.044 -0.069
61 16 1 0.000 -3.147 3.147 -0.000
62 16 2 0.410 -3.124 3.312 -0.943
63 16 2 0.410 -2.298 2.750 0.195
64 16 3 -0.820 -3.029 3.116 -0.101
65 17 1 0.000 -0.000 3.147 -0.000
66 17 2 0.410 0.009 3.365 -0.932
67 17 2 0.410 0.808 3.528 0.344
68 17 3 -0.820 0.110 3.227 -0.079
69 18 1 0.000 3.147 3.147 -0.000
70 18 2 0.410 3.627 3.290 -0.815
71 18 2 0.410 3.827 3.044 0.665
72 18 3 -0.820 3.303 3.152 -0.020
73 19 1 0.000 -3.147 -3.147 3.147
74 19 2 0.410 -2.868 -2.324 2.745
75 19 2 0.410 -2.811 -3.102 4.042
76 19 3 -0.820 -3.064 -3.030 3.213
77 20 1 0.000 -0.000 -3.147 3.147
78 20 2 0.410 0.137 -2.505 2.450
79 20 2 0.410 0.719 -2.993 3.759
80 20 3 -0.820 0.115 -3.040 3.135
81 21 1 0.000 3.147 -3.147 3.147
82 21 2 0.410 3.292 -3.435 2.246
83 21 2 0.410 4.014 -2.887 3.458
84 21 3 -0.820 3.283 -3.151 3.067
85 22 1 0.000 -3.147 -0.000 3.147
86 22 2 0.410 -2.401 0.357 2.664
87 22 2 0.410 -3.199 0.536 3.938
88 22 3 -0.820 -3.053 0.120 3.188
89 23 1 0.000 -0.000 -0.000 3.147
90 23 2 0.410 0.359 -0.592 2.486
91 23 2 0.410 0.298 -0.362 3.981
92 23 3 -0.820 0.088 -0.128 3.170
93 24 1 0.000 3.147 -0.000 3.147
94 24 2 0.410 3.699 0.100 2.372
95 24 2 0.410 3.760 -0.194 3.855
96 24 3 -0.820 3.304 -0.013 3.138
97 25 1 0.000 -3.147 3.147 3.147
98 25 2 0.410 -2.637 2.917 2.370
99 25 2 0.410 -2.507 3.160 3.858
100 25 3 -0.820 -2.992 3.118 3.138
101 26 1 0.000 -0.000 3.147 3.147
102 26 2 0.410 0.807 3.211 2.637
103 26 2 0.410 0.294 2.979 4.042
104 26 3 -0.820 0.148 3.133 3.199
105 27 1 0.000 3.147 3.147 3.147
106 27 2 0.410 3.964 3.249 2.659
107 27 2 0.410 3.418 2.809 4.000
108 27 3 -0.820 3.293 3.115 3.196
I got the output as below:
Scanning data file …
Reading data file …
orthogonal box = (-4.72 -4.72 -4.72) to (4.72 4.72 4.72)
1 by 1 by 1 processor grid
108 atoms
Finding 1-2 1-3 1-4 neighbors …
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
108 atoms in group water
27 rigid bodies with 108 atoms
Ewald initialization …
G vector = 0.273155
vectors: actual 1d max = 40 2 62
Setting up run …
Memory usage per processor = 2.09557 Mbytes
Step Temp E_pair E_bond E_angle Volume
0 178.16984 -5961.4573 0 0 841.23238
1000 300 -6051.303 0 0 841.23238
2000 300 -6063.6642 0 0 841.23238
3000 300 -6051.1059 0 0 841.23238
4000 300 -6059.3937 0 0 841.23238
5000 300 -6037.6275 0 0 841.23238
6000 300 -6003.0647 0 0 841.23238
7000 300 -6013.4112 0 0 841.23238
8000 300 -5925.6174 0 0 841.23238
9000 300 -5863.6547 0 0 841.23238
10000 300 -5534.0281 0 0 841.23238
11000 300 -5695.5609 0 0 841.23238
12000 300 -4890.5809 0 0 841.23238
13000 300 -4897.2194 0 0 841.23238
14000 300 -4274.6457 0 0 841.23238
14500 300 280.51906 0 0 841.23238
15000 nan nan 0 0 841.23238
15500 nan nan 0 0 841.23238
16000 nan nan 0 0 841.23238
Loop time of 111.471 on 1 procs for 50000 steps with 108 atoms
Pair time () = 88.1273 (79.0585)
Bond time () = 0.00457811 (0.004107)
Kspce time () = 4.22416 (3.78947)
Neigh time () = 14.3117 (12.839)
Comm time () = 2.81155 (2.52223)
Outpt time () = 0.00582933 (0.00522946)
Other time (%) = 1.98588 (1.78152)
Nlocal: 108 ave 108 max 108 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 4550 ave 4550 max 4550 min
Neighs: 31188 ave 31188 max 31188 min
Total # of neighbors = 31188
Ave neighs/atom = 288.778
Ave special neighs/atom = 0
Neighbor list builds = 5684
Dangerous builds = 3478
System init for write_restart …
G vector = 0.273155
ERROR: Insufficient Jacobi rotations for rigid body
