Hi Axel,
Thanks a lot for your help. I went through the paper you mentioned and couple of presentations given by Steve and other members. I also followed your advice at this thread https://lammps.sandia.gov/threads/msg13175.html. Unfortunately, I am unable to update the forces correctly with the methods outlined in the references.
I have three body potential with atom indices (i,j,k) and I followed the code structure as written in pair_tersoff.cpp. The force model that I am considering while developing IPs is from this equation
F_i = \sum_{j,k} dE(i,j,k)/dr_i + \sum_{j,k} dE(j,i,k)/dr_i + \sum_{j,k} dE(j,k,i)/dr_i
As you can see, I need to update the force vector for atom ‘i’ where atom ‘j’ or atom ‘k’ can be central atoms. Earlier, I implemented this by using tags which gave me forces corresponding to the model that we have developed. But when I switched to i,j,k obtained in the similar manner as in tersoff file, I am getting totally different forces from the model. Can you please help me in debugging this issue?
for (ii = 0; ii < inum; ii++) {
i = ilist[ii];
//localEnergy[i]=0.0;
itag = tag[i];
//i = itag-1; //Change -1
localEnergy[i]=0.0;
x_i = x[i][0]; //CENTRAL ATOM
y_i = x[i][1];
z_i = x[i][2];
itype = type[i];
jlist = firstneigh[i]; //Array of indexes of neighbours of central atom
jnum = numneigh[i]; //intger storing total number of neighbours for i atom
int numshort = 0;
//if(ii==0){
// std::cout<<"i j “<<i<<” "<<jlist[0]<<std::endl;
//two-body loop
for (jj = 0; jj < jnum; jj++) {
j = jlist[jj]; //j-th atom
jtag = tag[j];
//j = jtag-1; //CHANGE - 2
j &= NEIGHMASK; //NO-Clue about this line
if(ii==0){
if(jj==0){
std::cout<<"Inside i j “<<i<<” "<<j<<std::endl;
std::cout<<"itag jtag “<<itag<<” "<<jtag<<std::endl;
delxij = x_i - x[j][0]; //dr_ij
delyij = y_i - x[j][1]; //dr_ij
delzij = z_i - x[j][2]; //dr_ij
//domain->minimum_image(delxij,delyij,delzij);
rsq = delxijdelxij + delyijdelyij + delzij*delzij;
jtype = type[j];
/if (itag > jtag) {
if ((itag+jtag) 2 == 0) continue;
} else if (itag < jtag) {
if ((itag+jtag) 2 == 1) continue;
} else {
if (x[j][2] < z_i) continue;
if (x[j][2] == z_i && x[j][1] < y_i) continue;
if (x[j][2] == z_i && x[j][1] == y_i && x[j][0] < x_i) continue;
if (rsq < cutsq[itype][jtype]) {
r = sqrt(rsq);
nIndices = nIndices +1;
neighshort[numshort++] = j;
if (numshort >= maxshort) {
maxshort +=maxshort/2;
memory->grow(neighshort,maxshort,“pair:neighshort”);
twobodyDEBUG(paramO, r, delxij,delyij,delzij, energyA,forceAX,forceAY,forceAZ);
/*if(i==0){
std::cout<<"Len neigshort "<<numshort<<std::endl;
localEnergy[i] = energyATwoBWts;
dummy = forceAXTwoBWts;
f[i][0] += dummy[0,0];
dummy = forceAYTwoBWts;
f[i][1] += dummy[0,0];
dummy = forceAZ*TwoBWts;
f[i][2] += dummy[0,0];
jnumm1 = numshort- 1;
//f_I = arma::zeros(3,thD);
for (jj = 0; jj < jnumm1; jj++) {
//f_J = arma::zeros(3,thD);
j = neighshort[jj];
jtag = tag[j];
//if(j!=jtag){
// std::cout<<"j != jtag “<<std::endl;
// std::cout<<j<<” "<<jtag<<std::endl;
jtype = type[j];
x_j = x[j][0];
y_j = x[j][1];
z_j = x[j][2];
delrij[0] = x_i-x_j;
delrij[1] = y_i-y_j;
delrij[2] = z_i-z_j;
rijSq = delrij[0]*delrij[0] + delrij[1]*delrij[1] + delrij[2]*delrij[2];
for (kk = jj+1; kk < numshort; kk++) {
if(jj==kk) continue;
k = neighshort[kk];
k &= NEIGHMASK;
ktag = tag[k];
ktype = type[k];
x_k = x[k][0];
y_k = x[k][1];
z_k = x[k][2];
delrik[0] = x_i-x_k;
delrik[1] = y_i-y_k;
delrik[2] = z_i-z_k;
//domain->minimum_image(delrik[0],delrik[1],delrik[2]);
delrjk[0] = x_j-x_k;
delrjk[1] = y_j-y_k;
delrjk[2] = z_j-z_k;
//domain->minimum_image(delrjk[0],delrjk[1],delrjk[2]);
rikSq = delrik[0]*delrik[0] + delrik[1]*delrik[1] + delrik[2]*delrik[2];
rjkSq = delrjk[0]*delrjk[0] + delrjk[1]*delrjk[1] + delrjk[2]delrjk[2];
if (rjkSq<=4.0cutsq[itype][jtype]){
rij = sqrt(rijSq);
rjk = sqrt(rjkSq);
rik = sqrt(rikSq);
if (rik>cutoff){
std::cout<<"rik greater than cutoff "<<std::endl;
loopTwoStart = clock();
threebodyDEBUG(paramO,rij,rik,rjk,delrij,delrik,delrjk,thEnergyA,f_I,f_J,f_K,insideTHduration);
for(int tt=0;tt<3;tt++){
dummy = arma::dot(f_I.row(tt),ThBWts);
f[i][tt]+=dummy(0,0);
dummy = arma::dot(f_J.row(tt),ThBWts);
//if(j<inum){
f[j][tt]+=dummy(0,0);
//else{
// f[j+nlocal][tt]+=dummy(0,0);
dummy = arma::dot(f_K.row(tt),ThBWts);
f[k][tt]+=dummy(0,0);
//std::cout<<“DONE WITH ONE K LOOP”<<std::endl;
//f_J = f_J/repmat(ThBrangeLE,3,1);
//for(int tt =0; tt<3;tt++){
// dummy = arma::dot(f_J.row(tt),ThBWts);
// f[j][tt]+=dummy(0,0);
//f_I = f_I/repmat(ThBrangeLE,3,1);
// dummy = arma::dot(f_I.row(tt),ThBWts);
// f[i][tt]+=dummy(0,0);
dummy = thEnergyA*ThBWts;
localEnergy[i] = localEnergy[i] + dummy[0,0];
