Hi all,
I use thermal/conductivity to calculate the interfacial thermal conductivity in graphene-polymer nanocomposites at T=300 K. However, the temperature profile of my result varies greatly (Tmin=100, Tmax=500). Can anybody help me to solve this problem. The following is my input file.
Calculation of Interfacial Thermal Conductivity
########## Initialization ###########################################################################
units real
atom_style molecular
########## PCFF potential information (Class 2 Force-field) #########################################
neighbor 5.0 bin
neigh_modify every 1 delay 1
bond_style class2 # Define bond style
angle_style class2 # Define angle style
dihedral_style class2 # Define dihedral style
improper_style class2 # Define improper style
pair_style lj/class2 10.0
read_data data.Model_1 # Import geometrical data
########## Geometrical information ###################################################################
group polymer type 2 4 # Define polymer group
group graphene type 1 # Define graphene group
########## Output thermodynamics parameters ##########################################################
thermo_style custom step temp etotal vol ke
thermo 1000
thermo_modify lost warn
velocity polymer create 300 5812775 dist gaussian units box
velocity graphene create 300 5812778 dist gaussian units box
########## Calculate Temperature Profile #############################################################
compute ke all ke/atom
variable temp atom c_ke/(1.51.00.0019872041)
fix temp_polymer_profile polymer ave/spatial 10 10000 100000 z lower 0.05 v_temp file temp_polymer_1.profile units reduced
fix temp_graphene_profile graphene ave/spatial 10 10000 100000 z lower 0.5 v_temp file temp_graphene_1.profile units reduced
########## NVT Equilibration ##########################################################################
fix temp all temp/berendsen 300 300 5
fix nve all nve
timestep 0.25
run 500000
unfix temp
########## NEMD Calculation ###########################################################################
fix heat_swap all thermal/conductivity 200 z 20
fix e_exchange all ave/time 200 500 100000 f_heat_swap file e_exchange_1.dat
run 5000000
Kind regards,
M.C.
