Hi!
I have computed a long LAMMPS trajectory file (“dump.atom.velocity”) of a polymer melt. The polymers are all equally long and consist of identicaI beads and therefore dump.atom.velocity only have one type of “atoms”:
ITEM: TIMESTEP
120000000
ITEM: NUMBER OF ATOMS
13884
ITEM: BOX BOUNDS pp pp pp
0.0000000000000000e+00 2.9160000000000000e+01
ITEM: ATOMS id type xu yu zu vx vy vz
1986 1 0.968692 0.680136 0.0757868 0.372842 0.113453 0.640207
2176 1 4.29323 0.627803 0.26113 0.230537 0.388602 -1.14057
10940 1 5.57609 0.609709 0.254456 0.0917534 -1.13059 -0.261823
10939 1 6.51302 0.397487 0.318086 0.34501 -1.95721 -2.18305
7049 1 10.6491 0.277631 0.699386 1.63733 0.890773 -0.574776
I’ve computed the intermediate scattering function using DYNASOR without problems but I now got a request on computing the inter and intra-molecular polymer parts of F(Q,t) using the trajectory file.
Are there any functionality in DYNASOR to do this? Since the above file does not say anything about which polymers the different beads belong to, it appears the answer is negative? What is the quickest solution to this problem? From the numbering of beads, I can of course figure out which polymer a bead belongs to using the number of beads in a polymer.
./Jens
