Invalid compute ID in variable formula
Dear LAMMPS users,
I am using CNA to determine where are defects after the cascade in bcc Fe.
To do so, I use the following after the cascade has taken place:
compute cnatom all cna/atom 3.45
thermo_style custom step temp
run 0
Determine which defects have a structure different than BCC (3)
variable cna atom “c_cnatom == 5”
group groupcna dynamic all var cna every 1
run 0
variable nbdefects equal count(groupcna)
print “Number of defects = ${nbdefects}”
Since the cna calculation is quite computationally expensive, I remove these compute before I continue other calculations.
uncompute cnatom
other commands…
run 1000
And there I get the following error:
ERROR: Invalid compute ID in variable formula (…/variable.cpp:1257)
I understand why this occurs (because of the variable atom that is referenced) but I do not know how to solve it. Any idea?
Many thanks in advance and best regards,
Christophe
Well, you can’t expect to evaluate a variable
if a compute it uses has been deleted.
There is a variable delete command. Or just
don’t evaluate either the variable or compute.
LAMMPS won’t give an error unless you
request they be evaluated.
