Invalid pair style
i am using pair_style meam, and it gives me an error invalid pair style. I am not sure if meam is installed or not! But i have a copy of the commands I used in the installation:
cd ./MAKE
cp Makefile.g++3 Makefile.g++3_ORIG
Edit Makefile.g++3: CCFLAGS = -O
LINKFLAGS = -O
you should add the meam package to the build (make yes-meam), but before compiling it, you should first compile the meam library in lib/ (it has a README file with instructions). See also http://lammps.sandia.gov/doc/Section_start.html#start_3_3
Kristof
