inverse-power potential
Dear LAMMPS Users,
I want to use a purely repulsive A/r^12 potential.
LAMMPS does not seem to have an inverse-power potential implemented and there is no version of the LJ potential where the r^-12 and r^-6 coefficient can given independently (E=A/r^12-B/r^6, like in gromacs for instance)
I am wondering what would happen if I would use a Mie potential with gamma_rep=12 and gamma_att=0 ? Would C be undetermined or could it return a value of 1 ? Could someone suggest a work-around possibly other than a tabulated potential to get this inverse-power potential ?
Thank you in advance for helping
Dear LAMMPS Users,
for instance)
the computation of C would cause a division by zero and thus make this
path unattainable.
what is your objection against tabulation?
if people want a purely repulsive r^12 term, they usually take a 12-6
LJ and put the cutoff in the minimum of the potential.
otherwise, you have to grab a text editor and do some programming.
LAMMPS is designed so that it is fairly easy to add another pair
potential.
axel
This should be a quick fix. Copy and rename the 6-12 LJ to whatever you like and take out all the occurances where the r^6 piece is calculated.
And that cutoff is 2^(1/6) sigma.
