brian,
Thanks guys. Only 0.5% of my system is charged particles (200 charged,
~44,000 uncharged) so it really is a toss up as to what will happen like you
guys are saying. I'll just have to run it and see.
if you need long-range electrostatics on that,
you should definitely go for using hybrid overlay
and the pppm/cg kspace style.
i am copying an example input below for an
coarse grain SDS surfactant monolayer input.
this kind of setup benefits a _lot_ from OpenMP or GPU.
GPU is particularly interesting, since the GPU non-bonded
kernels can run at the same time as the kspace and bonded.
since non-bonded on the GPU is fairly fast, performance is
often determined by the performance of pppm and here
the charged atom list optimization in pppm/cg is a big win.
i've seen 20% speedup vs. pppm and more.
...and again, you can accelerate kspace even more by
playing with the real space cutoff for coulomb. the multi
neighborlist style handles this very efficiently.
good luck,
# lammps input script
units real
atom_style full
processors * * 1
read_data DATA.FILE
pair_style hybrid/overlay cg/cmm/omp 15.0 coul/long/omp 25.0
bond_style harmonic
angle_style cg/cmm
special_bonds lj/coul 0.0 0.0 1.0
mass 1 96.0576 # SO4
mass 2 42.0804 # CM
mass 3 43.0883 # CT
mass 4 77.0342 # SOD
mass 5 54.0460 # W
pair_coeff 1 1 coul/long/omp # SO4 SO4
pair_coeff 1 4 coul/long/omp # SO4 SOD
pair_coeff 4 4 coul/long/omp # SOD SOD
pair_coeff 1 1 cg/cmm/omp lj9_6 0.7000 4.3210 # SO4 SO4
pair_coeff 1 2 cg/cmm/omp lj9_6 0.3830 4.4135 # SO4 CM
pair_coeff 1 3 cg/cmm/omp lj9_6 0.4050 4.4530 # SO4 CT
pair_coeff 1 4 cg/cmm/omp lj12_4 1.1000 4.1000 # SO4 SOD
pair_coeff 1 5 cg/cmm/omp lj12_4 1.1000 4.1000 # SO4 W
pair_coeff 2 2 cg/cmm/omp lj9_6 0.4200 4.5060 # CM CM
pair_coeff 2 3 cg/cmm/omp lj9_6 0.4440 4.5455 # CT CM
pair_coeff 2 4 cg/cmm/omp lj12_4 0.3400 4.4385 # SOD CM
pair_coeff 2 5 cg/cmm/omp lj12_4 0.3400 4.4385 # W CM
pair_coeff 3 3 cg/cmm/omp lj9_6 0.4690 4.5850 # CT CT
pair_coeff 3 4 cg/cmm/omp lj12_4 0.3600 4.4780 # SOD CT
pair_coeff 3 5 cg/cmm/omp lj12_4 0.3600 4.4780 # W CT
pair_coeff 4 4 cg/cmm/omp lj12_4 0.3500 4.3710 # SOD SOD
pair_coeff 4 5 cg/cmm/omp lj12_4 0.8950 4.3710 # SOD W
pair_coeff 5 5 cg/cmm/omp lj12_4 0.8950 4.3710 # W W
bond_coeff 1 11.0000 3.6300 # SO4 CM
bond_coeff 2 6.1600 3.6400 # CM CM
bond_coeff 3 6.1600 3.6500 # CM CT
angle_coeff 1 1.1000 178.0000 lj9_6 0.3830 4.4135 # SO4 CM CM
angle_coeff 2 1.1900 173.0000 lj9_6 0.4200 4.5060 # CM CM CM
angle_coeff 3 1.1900 175.0000 lj9_6 0.4440 4.5455 # CM CM CT
replicate 8 8 1
group charged type 1 4
atom_modify first charged
kspace_style pppm/cg 0.00001
kspace_modify order 3
communicate multi
neighbor 2.0 multi
neigh_modify delay 4 every 2 check yes
timestep 10.0
fix 1 all nvt temp 310.0 310.0 100.0 drag 0.1
thermo_style custom step pe temp evdwl ecoul spcpu
thermo 500
velocity all create 325.0 63443
run 10000
