I realize that a Firework has a unique id and comprises of various FireTasks. My question is, is it possible to add an additional Task to an existing Firework a-posteriori (after it has been added to mongodb and run), and run the Firework again only from the newly added task.
To provide more details, consider the fw_test.yaml in introduction
spec:
_tasks:
- _fw_name: ScriptTask
script: echo “howdy, your job launched successfully!” >> howdy.txt
Now I add this yaml file to the mongodb and launch it through commandline
lpad reset
lpad add fw_test.yaml
rlaunch singleshot
Now is it possible for me to add a new task directly to the FireWork in database, so that it will look like
spec:
_tasks:
script: echo “howdy, your first task launched successfully!” >> howdy.txt
script: echo “howdy, your second task launched successfully!” >> howdy.txt
and if I run this Firework again, it must run the second task so that the *howdy.txt * has
Hi Janakiraman,
There is no way to do this at the FireTask level, unless you really hack the update_spec method (not recommended). However, you can add another FireWork or Workflow to the end using the LaunchPad.append_wf() method. This will also make sure that your initial job does not get run again.
Also - this is tangential - but there is task-level recovery mechanism for FireWorks that originated with multiple FireTasks: https://pythonhosted.org/FireWorks/rerun_tutorial.html
Anubhav
On Wed, Feb 3, 2016 at 9:33 AM, Janakiraman Balachandran [email protected] wrote:
spec:
_tasks:
lpad reset
rlaunch singleshot
spec:
_tasks:
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/38d08395-13e6-4b7c-b690-40684b6556ee%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Hi Anubhav,
Thank you. I’m working on fireworks 1.04 and cannot update for some dependency issues. I tested LaunchPad.add_wf_to_fws() for some simple tasks and it seems to work. Let me know if there is anything important that is different between append_wf () in latest version and add_wf_to_fws() that I’m currently using.
Thank you,
Best
Ram
On Wednesday, February 3, 2016 at 4:00:10 PM UTC-5, ajain wrote:
Hi Janakiraman,
Anubhav
spec:
_tasks:
lpad reset
rlaunch singleshot
spec:
_tasks:
It would also be helpful if you explain what does the other two options ’ detour=False, pull_spec_mods=True ’ in the function actually mean.
On Wednesday, February 3, 2016 at 4:18:37 PM UTC-5, Janakiraman Balachandran wrote:
Hi Anubhav,
Thank you,
Best
Ram
Hi Janakiraman,
Anubhav
spec:
_tasks:
lpad reset
rlaunch singleshot
spec:
_tasks:
Hi Ram
Important changes are typically listed here:
https://pythonhosted.org/FireWorks/changelog.html
(normally the refactor would also be listed there, but missing this time)
In this case, there should be no important differences. For the options, I’ve just documented append_wf() parameters for the future. They are
:param new_wf: (Workflow) The new workflow to append
:param fw_ids: ([int]) The parent fw_ids at which to append the workflow
:param detour: (bool) Whether to connect the new Workflow in a “detour” style, i.e., move original children of the parent fw_ids to the new_wf
:param pull_spec_mods: (bool) Whether the new Workflow should pull the FWActions of the parent fw_ids
On Wednesday, February 3, 2016 at 1:20:13 PM UTC-8, Janakiraman Balachandran wrote:
Hi Anubhav,
Thank you,
Best
Ram
Hi Janakiraman,
Anubhav
spec:
_tasks:
lpad reset
rlaunch singleshot
spec:
_tasks:
