Is it possible to assign charge in LAMMPS
Dear All
I want to assign charge in individual atom of a polymer contain around 122 atoms. Is it possible to assign charge during simulation in LAMMPS?
Thanks in advance
Anderson
Dear All
http://lammps.sandia.gov/doc/set.html
Dear Axel
Thank you for your comments
In the set command might be I could insert the charge value for a particular atom types? However, If I dont know the charge value then is it possible to calculate and assign it during simulation? Actually in my polymer the charge is very much fluctuated atom to atom. Therefore, if I want to assign the charge by considering atom type then I could consider several types of atom and I also have several number of polymer in my system.
Thanks in advance
Anderson
Dear Axel
system.
​how about you _first_ read the documentation of the set command properly
and carefully, and _then_ ask questions about specific details given in
there?
even for a fast reader and LAMMPS expert it is impossible to read the
entire pages, understand it and write an e-mail reply in under 10 minutes...
​axel.​
Dear Axel
Thank you for your comments. Actually I have used the set command previously. However, I have solved the problem. Now its OK
Thank you
Anderson
