Dear LAMMPS users,
Is pair_style tersoff together with the potential file Si.tersoff enough to describe the properties of Si? Do I need to set the bond, angle, and dihedral types? Thanks.
Regards,
Kira Banks
Dear LAMMPS users,
Regards,
Kira Banks
Dear LAMMPS users,
yes. well, within the limitation of the given parameterization, that is.
dihedral types?
does the documentation tell you to do so anywhere? no.
in fact, if you look through the mailing list archive, you'll
come across discussions, how that can create problems
through the implied excluded interactions on the neighborlists
from the bonds, angles and dihedrals.
you should read some of the papers on the parameterization
of tersoff potential and see how it models interactions.
cheers,
Hi Kira,
Depends on what properties you wish to describe and model. Tersoff
produces Si properties as good as said in its publication.
No, you don't; just use atom_style atomic. Tersoff is a pure atomic
empirical potential and it will determine bonds and angles for you,
but not dihedrals.
Dear Alex,
Thanks a lot.
Bests,
Kira
Dear Ray,
Thanks a lot.
Bests,
Kira
