I am worried about it because I have done some tests with pbc.I put one water molecule in the center of the cell, and at the boundary of the cell. The force calculated are different, which I think should be the same.
Can you explain it?
I print out the force acted on the atoms after the reverse_comm().
With the water in the middle of the box, the result I get is
Can you explain it?
there are two components:
1) pppm is not completely position invariant.
2) the parameter estimator for kspace does not work well for low charge density.
so:
- use a tighter convergence for pppm
- use the estimator for pppm with a normal density water system and
look up the resulting parameters (grid, gewald) and then use those.
> Dear lammps users,
cell.
> Can you explain it?
density.
Thank you for your help. The tighter convergence can solve the problem. But
do you know is there a way to change these parameters, or I have to coding
for it?
> Dear lammps users,
> cell.
> Can you explain it?
density.
for it?
just follow the second suggestion in combination with the first.
