Is there an easy way to include arbitrary convergence constr
The -itol=… does not work very well for my particular system. I would like to stop mcsqs when three different instances of the code generate the same structure.
You easily write a script that does a diff on the different bestsqs?.out files if two match, create a stopsqs file to make the codes stop cleanly.
