Dear All,
There was a problem when I calculated the intrinsic stacking fault (ISF) of Si. Two different potentials, namely, Tersoff (J. Tersoff, PRB, 37, 6991 (1988)) and SW (Stillinger and T. Weber, Phys. Rev. B, 31, 5262, (1985)), were used. Different simulation boxes were tested. The ISF was finally obtained as 0.112 eV/A2 for Tersoff and 0.096 eV/A2 for SW, both are much greater than that of DFT method with a result of 0.006 eV/A2 (Phys. Rev. B, 50, 5890, 1994 ). I tried to solve this problem, but I failed at last.
I set the orients x [112], y [-110], z [-1-11], the displacement of a half relative to another bp= a/6[112]= 5.4308 A. My code is as follows,
------------------------ INITIALIZATION ----------------------
boundary p p s
atom_style atomic
variable latparam1 equal 5.4308
variable xdim equal {latparam1}*sqrt(6)/2*30 variable ydim equal {latparam1}sqrt(2)/230
----------------------- ATOM DEFINITION ----------------------
lattice diamond ${latparam1}
region 1 block 0 {xdim} 0 {ydim} 0 100
region 2 block 0 {xdim} 0 {ydim} 100 200
region whole block 0 {xdim} 0 {ydim} 0 100 units box
create_box 1 whole
lattice diamond ${latparam1} orient x 1 1 2 orient y -1 1 0 orient z -1 -1 1
create_atoms 1 region 1
create_atoms 1 region 2
----------------------- FORCE FIELDS -----------------------
pair_style tersoff
pair_coeff * * Si.tersoff Si
------------------------- SETTINGS --------------------------
group top region 1
group bot region 2
------------------------- Displacement -----------------------
displace_atoms bot move -2.2171 0.0 0.0 units box
compute peratom all pe/atom
compute eatoms all reduce sum c_peratom
Dump to comp for Ovito post processing
dump 1 all custom 1 dump.comp.* id type xs ys zs c_peratom fx fy fz
thermo 1
thermo_style custom step pe c_eatoms
mass * 1.0
fix 1 all setforce 0 0 NULL
min_style cg
minimize 1e-10 1e-10 1 1
SIMULATION DONE
print ${x}
print “All done”
----------------------- END --------------------
Are there any mistakes in my code for the large discrepancy?
Thank
in advance.
Sincerely,
-Wilhelm
