Hello, I am new to lammps and am having trouble running this one script. When I run “mpiexec -np 4 lmp_mpi -in in.pour” in the command window, I get this:
“LAMMPS (7 Aug 2019)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (…/comm.cpp:93)
ERROR: Unknown command: communicate single vel yes (…/input.cpp:232)
Last command: communicate single vel yes”
Do I need to download some MPI? If so, which is best suited for windows 10? Please let me know. Thanks!
no. you need to update the syntax of the input file. where did you get it from?
if you look at the in.pour file in the examples/pour/ folder, you will find the correct syntax.
I believe that command is deprecated and you need to use:
comm_modify
rather than communicate.
https://lammps.sandia.gov/doc/comm_modify.html
-Keith
This is the closest I get I guess.
C:\Users\walee\EK125>mpiexec -np 4 lmp_mpi -in in.pour
LAMMPS (7 Aug 2019)
ERROR: Illegal comm_modify command (…/comm.cpp:341)
Last command: comm_modify single vel yes
