issue with fix ave/spatial
Dear All,
I am using LAMMPS (28 Mar 2012) build
fix 1 all ave/spatial 10 100 1000 y lower 10.0 c_stN11[2] units box
I want to get output of one bin using:
variable strD1 equal f_1[4][6]
fix print_2 all print 1000 “${strD1}” file temp.txt
However, there is error:
ERROR: Variable formula fix array is accessed out-of-range
What could be the problem?
Many thanks,
Rajib
Dear All,
                         fix 1 all ave/spatial 10 100 1000 y lower 10\.0
                        variable strD1 equal f\_1\[4\]\[6\]
                        fix print\_2 all print 1000 "$\{strD1\}" file
temp.txt
out-of-range
that you are trying to access an array element that doesn't exist?
if you want more specific help, you have to provide more details,
best a small but working input.
The fix ave/spatial output array doesn't have 6 columns for
your command. You probably mixed up the row and column indices
in your variable def.
Thanks Axel and Steve. This is sorted out. I mixed-up row and columns.
Thanks for your help.
