I successfully compiled the latest version of LAMMPS with GPU package using OpenCL, but I get an error after running my script on my workstation with 40 cores and having the latest version of ubuntu:
package gpu 0 split 1.0 tpa 2 omp 1
suffix gpu
- Using acceleration for eam/alloy:
- with 40 proc(s) per device.
- with OpenCL Parameters for: NVIDIA_GPU (203)
- Horizontal vector operations: ENABLED
- Shared memory system: No
Device 0: Quadro K620, 3 CUs, 2 GB, 1.1 GHZ (Mixed Precision)
Initializing Device and compiling on process 0…Done.
Initializing Device 0 on core 0…Done.
Initializing Device 0 on core 1…Done.
Initializing Device 0 on core 2…Done.
Initializing Device 0 on core 3…Done.
Initializing Device 0 on core 4…Done.
Initializing Device 0 on core 5…Done.
Initializing Device 0 on core 6…Done.
Initializing Device 0 on core 7…Done.
Initializing Device 0 on core 8…Done.
Initializing Device 0 on core 9…Done.
Initializing Device 0 on core 10…Done.
Initializing Device 0 on core 11…Done.
Initializing Device 0 on core 12…Done.
Initializing Device 0 on core 13…Done.
Initializing Device 0 on core 14…Done.
Initializing Device 0 on core 15…Done.
Initializing Device 0 on core 16…Done.
Initializing Device 0 on core 17…Done.
Initializing Device 0 on core 18…Done.
Initializing Device 0 on core 19…Done.
Initializing Device 0 on core 20…Done.
Initializing Device 0 on core 21…Done.
Initializing Device 0 on core 22…Done.
Initializing Device 0 on core 23…Done.
Initializing Device 0 on core 24…Done.
Initializing Device 0 on core 25…Done.
Initializing Device 0 on core 26…Done.
Initializing Device 0 on core 27…Done.
Initializing Device 0 on core 28…Done.
Initializing Device 0 on core 29…Done.
Initializing Device 0 on core 30…Done.
Initializing Device 0 on core 31…Done.
Initializing Device 0 on core 32…Done.
Initializing Device 0 on core 33…Done.
Initializing Device 0 on core 34…Done.
Initializing Device 0 on core 35…Done.
Initializing Device 0 on core 36…Done.
Initializing Device 0 on core 37…Done.
Initializing Device 0 on core 38…Done.
Initializing Device 0 on core 39…Done.
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
max neighbors/atom: 10000, page size: 100000
master list distance cutoff = 8.506786
ghost atom cutoff = 8.506786
binsize = 5.506786, bins = 44 19 55
0 neighbor lists, perpetual/occasional/extra = 0 0 0
Setting up Verlet run …
Unit style : metal
Current step : 0
Time step : 0.001
OpenCL error in file ‘/home/cauchy/Desktop/LAMMPS/lammps-4May2022/lib/gpu/geryon/ocl_kernel.h’ in line 467 : -4.
MPI_ABORT was invoked on rank 38 in communicator MPI_COMM_WORLD
with errorcode -1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[cauchy:1193482] PMIX ERROR: UNREACHABLE in file …/…/…/src/server/pmix_server.c at line 2193
[cauchy:1193482] 31 more processes have sent help message help-mpi-api.txt / mpi-abort
[cauchy:1193482] Set MCA parameter “orte_base_help_aggregate” to 0 to see all help / error messages
