Hello. I tried NPT simulation of ionic crystal in triclinic cell.
With temperature above 400K, crystals become melts.
In this simulation, pair correlation function shows weird peak below 0.5 A which is impossible because of the non bonding interactions.
To check this problem, I checked the coordinates of atoms in my simulation. I found that wrapped and unwrapped coordinates are differ.
Can anyone can explain this strange things?
Thank you.
======= My script =========
units real
atom_style full
neighbor 3.0 bin
neigh_modify delay 0 every 1 check yes page 500000 one 50000
variable r index 10000
variable dcd index 100
variable t index 400
variable ts index 1.0
variable a equal 100.0*${ts}
variable b equal 1000.0*${ts}
pair_style lj/cut/coul/long 10.0
bond_style harmonic
angle_style harmonic
dihedral_style charmm
improper_style cvff
kspace_style ewald 0.0001
pair_modify shift yes mix geometric
special_bonds lj/coul 0.0 0.0 0.5
read_data re.init
fix 1 all npt temp $t $t $a iso 1.0 1.0 $b
thermo ${dcd}
timestep ${ts}
dump 1 all dcd ${dcd} posnpt1_no.dat
dump_modify 1 unwrap no
dump 2 all dcd ${dcd} posnpt1_yes.dat
dump_modify 2 unwrap yes
run $r
write_restart re.dcd
