issues while generating MCSQS for partially delithiated layered LiCoO2 system
I rand five different mcsqs calculation for 50% delithiated LiCoO2 layered system. All 5 caculations giving me same objective function. Kindly suggest if i am using the mcsqs in wrong manner and How could I correct it.
rndstr.in file
2.82 2.82 14.10 90 90 120
1 0 0
0 1 0
0 0 1
0.000000 0.000000 0.000000 Li=0.50,Va=0.50
0.000000 0.000000 0.500000 Co
0.000000 0.000000 0.244500 O
0.000000 0.000000 0.755500 O,
sqscell.out
1
2 0 0
0 2 0
0 0 2
bestcorr.out
2 2.820000 0.000000 0.000000 0.000000
2 4.884383 0.000000 0.000000 0.000000
2 5.640000 1.000000 0.000000 1.000000
3 2.820000 0.000000 0.000000 0.000000
3 4.884383 0.000000 0.000000 0.000000
Objective_function= -3.000000
mcsqs.log
Reading supercells…
Initializing random supercells…
Initialization done.
Objective_function= -1.722222
Correlations_mismatch= -0.333333 -0.333333 1.000000 0.000000 0.000000 0.000000
Correlations_mismatch= 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000
The error is there for 25% delithiated as well as 75% delithiated structure.
Hello! I think the reason why you get the same objective function stems from the fact that you are simulating a small system. You have a 2x2x2 cell with 1 site of interest in each unit cell, meaning there’s only 8 choose 4 = 70 ways to distribute your Li and Va. These 70 will be dramatically reduced due to symmetry and your computer will be able to enumerate all the options quickly, finds the best possible sqs for the system size you have chosen, and the objective function for that cell is the one you will get every time.
If you have the computational power, you will probably need a larger cell if your goal is to represent disorder better. In your case, you also have one very long axis where the interactions within the layers are much stronger than between layers, so I would look into a 4x4x1 or 6x4x1 cell before doubling along the long axis. Note how your 3rd 2-body cluster is 100 % correlated because 5.64 is the size of your unit cell.
