Hello LAMMPS developers, I have the following problem when run the example for temper_grem (inpust in the directory ~/lammps/examples/PACKAGES/grem/lj-temper/
when I run:
mpirun -np 4 ~/lammps/build/lmp -p 4x1 -in in.gREM-temper
LAMMPS (29 Aug 2024)
Running on 4 partitions of processors
Abort(1) on node 1 (rank 1 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
I don’t know what happen because when I run the example of in.melt using 4 cpus there is not problem
mpirun -np 4 ~/lammps/build/lmp -in in.melt
LAMMPS (29 Aug 2024 - Update 1)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
Lattice spacing in x,y,z = 1.6795962 1.6795962 1.6795962
Created orthogonal box = (0 0 0) to (16.795962 16.795962 16.795962)
1 by 2 by 2 MPI processor grid
Created 4000 atoms
using lattice units in orthogonal box = (0 0 0) to (16.795962 16.795962 16.795962)
create_atoms CPU = 0.001 seconds
Generated 0 of 0 mixed pair_coeff terms from geometric mixing rule
Neighbor list info …
update: every = 20 steps, delay = 0 steps, check = no
master list distance cutoff = 2.8
ghost atom cutoff = 2.8
binsize = 1.4, bins = 12 12 12
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut, perpetual
attributes: half, newton on
pair build: half/bin/atomonly/newton
stencil: half/bin/3d
bin: standard
Setting up Verlet run …
Unit style : lj
Current step : 0
Time step : 0.005
Per MPI rank memory allocation (min/avg/max) = 2.706 | 2.706 | 2.706 Mbytes
Step Temp E_pair E_mol TotEng Press
0 3 -6.7733681 0 -2.2744931 -3.7033504
50 1.6842865 -4.8082494 0 -2.2824513 5.5666131
100 1.6712577 -4.7875609 0 -2.281301 5.6613913
150 1.6444751 -4.7471034 0 -2.2810074 5.8614211
200 1.6471542 -4.7509053 0 -2.2807916 5.8805431
250 1.6645597 -4.7774327 0 -2.2812174 5.7526089
Loop time of 0.140831 on 4 procs for 250 steps with 4000 atoms
Performance: 766876.510 tau/day, 1775.177 timesteps/s, 7.101 Matom-step/s
99.0% CPU use with 4 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.065507 | 0.093171 | 0.10357 | 5.3 | 66.16
Neigh | 0.013328 | 0.016726 | 0.018237 | 1.5 | 11.88
Comm | 0.01486 | 0.027464 | 0.059723 | 11.3 | 19.50
Output | 0.00021964 | 0.00025251 | 0.00031458 | 0.0 | 0.18
Modify | 0.0015173 | 0.0019865 | 0.0022271 | 0.6 | 1.41
Other | | 0.00123 | | | 0.87
Nlocal: 1000 ave 1008 max 987 min
Histogram: 1 0 0 0 0 0 1 0 1 1
Nghost: 2711.25 ave 2728 max 2693 min
Histogram: 1 0 0 0 0 2 0 0 0 1
Neighs: 37947 ave 38966 max 37338 min
Histogram: 1 1 0 1 0 0 0 0 0 1
Total # of neighbors = 151788
Ave neighs/atom = 37.947
Neighbor list builds = 12
Dangerous builds not checked
Total wall time: 0:00:00
and I build the lammps from stable version using the following commnad:
cmake -DCMAKE_C_COMPILER=icx -DCMAKE_CXX_COMPILER=icpx -DCMAKE_Fortran_COMPILER=ifx -D PKG_KSPACE=yes -D PKG_REPLICA=yes …/cmake
I hope can you help me.
Samuel
