I tried to run the example of creating a Widget in Jupyter lab as the codes below:
from ovito.io import *
from ovito.vis import *
from ovito.modifiers import *
import ipywidgets
# Import a simulation model and set up a data pipeline:
pipeline = import_file('sample_data/NanocrystallinePd.dump.gz')
pipeline.add_to_scene()
pipeline.modifiers.append(ColorCodingModifier(property = 'Potential Energy', start_value = -4.02645, end_value = -3.43657))
# Create a virtual viewport:
vp = Viewport(type=Viewport.Type.Perspective, camera_dir=(-2, -1, -1))
vp.zoom_all()
# Create the visual viewport widget:
widget = vp.create_jupyter_widget()
widget.layout = ipywidgets.Layout(width='500px', height='400px')
display(widget)
But I got a error like:
TraitError: The '_orbit_center' trait of a JupyterViewportWidget instance expected a tuple, not the ndarray array([ 0.00025, 0. , -0.00065]).
I modified line 70 and 118 in _jupyter_widget.py then it works to add extra tuple().
self._orbit_center = tuple(self.viewport.orbit_center) if self.viewport) else (0.0, 0.0, 0.0)
