Dear lammps users,
I am testing the model_ArCHHeXe_BOP_AIREBO__MO_154399806462_001 in KIM coupling with lammps, but is experiencing some fatal error.
Somehow following error occurs when using the potential.
At line 396 of file model_ArCHHeXe_BOP_AIREBO.F03
Fortran runtime error: End of record
Anyone facing this issue pls indicate how should I fix the coupling problem. DO I need edit invoked codes in order to eliminate internal error/bug existing?
Dear Dr.Axel, would you pls help to take a close look the attached input file.Thank you very much!
Many thx in advance.
CH.airebo (942 KB)
in.kimhybrid.test (1.07 KB)
