Hi Jakob,
Thanks for your questions! I've taken a bit of time to respond in full so that I could respond comprehensively. Please see below
I am building OpenKIM support into my simulation software Asap. I have a question or two about memory management, in particular relating to parallel MD where atoms will migrate between processors, and the total number of atoms will vary.
I see the following steps in the code.
1) Match the model with KIM_API_string_init()
2) Allocate memory.
The example tests use KIM_API_allocate(), but the documentation warns against using it with KIM_API_set_data to avoid memory leaks. Also, KIM_API_allocate() takes the number of particles as an argument, and can only be called once, so it appears to be unsuitable for parallel simulations with varying particle number. As I understand the docs, I can use KIM_API_set_data instead (hence the warning against doing both), but which data structures does KIM_API_allocate allocate (i.e. what should I do instead)?
To respond to this I've written new version of the KIM_API_init() and KIM_API_allocate() function documentation that describes in detail what they do. I'll paste this information below. I expect to release this updated documentation with the next openkim-api release. If you have any questions/suggestions/comments/corrections to help improve the documentation, they are always welcome.
int KIM_API_init(void *kimmdl, char *testname, char *modelname);
This routine creates the KIM API object that can store every pointer to the
data described in the KIM descriptor file for the model. It also checks if
arguments described in descriptor files (Tests and Models) are compatible
with KIM standard naming convention (stored in the file `standard.kim') and
if Models are compatible with Tests. It will return KIM_STATUS_OK upon
successful completion or KIM_STATUS_FAIL otherwise. Also if it is
unsuccessful, kimmdl will have NULL value.
Here the process of matching a Test KIM descriptor file and a Model KIM
descriptor file is described in detail. For a final positive match result
to occur, a positive match must be obtained in EACH AND EVERY ONE of the
below steps:
(1) Syntax and standard conformance: The Test and Model KIM descriptor
files are read. Each item in the file is parsed and compared for
correct syntax and conformance with the `standard.kim' file. If both
the files a syntactically correct and conform to the `standard.kim'
file definitions, a positive match is obtained. Otherwise, a negative
match is obtained and the routine returns KIM_STATUS_FAIL.
(2) Unit matching: If the Model's Unit_Handling value is `flexible' a
positive match is obtained and the routine skips to the next step
below. Otherwise, the Test's base unit values are compared, one by
one, to the Model's base unit values. If all five values are equal, a
positive match is obtained. Otherwise, a negative match is obtained
(3) Particle type matching: For each particle type symbol name listed by
the Test, the Model's list of particle type symbol names is searched
for the corresponding entry. If every particle type symbol listed by
the Test is found in the Model's symbol list, a positive match is
obtained. If both the Model's and Test's list are empty, then the
model and test support a single "unnamed" particle type and a positive
match is obtained. Otherwise, a negative match is obtained and the
(4) Neighbor list access matching: The following is a list of the possible
cases and their matching result.
Test Model Matching Result
Iter Iter positive match
Iter Loca negative match
Iter Iter&Loca positive match
Iter Both negative match
Loca Iter negative match
Loca Loca positive match
Loca Iter&Loca positive match
Loca Both negative match
Iter&Loca Iter positive match
Iter&Loca Loca positive match
Iter&Loca Iter&Loca positive match
Iter&Loca Both positive match
Both Iter positive match
Both Loca positive match
Both Iter&Loca positive match
Both Both positive match
(5) NBC method matching: If one or more of the Test's listed NBC methods is
also in the Model's listed NBC methods a positive match is obtained.
When more than one common NBC method exists, the NBC method listed
closest to the top of the Test's NBC method list is selected as the
"active" NBC method. If no common NBC methods are listed a negative
(6) Matching for MODEL_INPUT arguments required by active NBC method:
Depending on the active NBC method (determined in step (5) above), the
Model's and Test's MODEL_INPUT section must include the following
arguments:
CLUSTER:
`coordinates'
NEIGH_PURE_H:
`coordinates'
`numberContributingParticles'
`neighObject'
`get_neigh'
NEIGH_PURE_F:
`coordinates'
`neighObject'
`get_neigh'
NEIGH_RVEC_H:
`coordinates'
`neighObject'
`get_neigh'
NEIGH_RVEC_F:
`coordinates'
`neighObject'
`get_neigh'
MI_OPBC_H:
`coordinates'
`boxSideLengths'
`neighObject'
`get_neigh'
MI_OPBC_F:
`coordinates'
`boxSideLengths'
`neighObject'
`get_neigh'
If all required arguments are found in both the Model's and Test's list
of MODEL_INPUT arguments, then a positive match is obtained.
Otherwise, a negative match is obtained and the routine returned
KIM_STATUS_FAIL.
(7) Mandatory arguments matching: The following arguments are mandatory and
must be included in any KIM descriptor file:
MODEL_INPUT section
`numberOfParticles'
`numberParticleTypes'
`particleTypes' (not required if the
SUPPORTED_ATOM/PARTICLES_TYPES
section is empty. That is, if the Model
and Test only support a single "unnamed"
particle type.)
`coordinates' (this has already been confirmed in step 6)
MODEL_OUTPUT section
`compute'
`reinit'
`destroy'
`cutoff'
If all of the above arguments (except possibly, as described above,
`particleTypes') are present in both the Model and Test KIM descriptor
files, then a positive match is obtained. Otherwise, a negative match
(8) MODEL_INPUT matching: If the Model's MODEL_INPUT list of arguments
includes `process_dEdr' or `process_d2Edr2', then its MODEL_OUTPUT list
of arguments may not contain `virial', `particleVirial', or `hessian'.
If it does, a negative match is obtained and the routine returns
KIM_STATUS_FAIL.
If the Test's MODEL_INPUT list of arguments includes `process_dEdr' or
`process_d2Edr2', then its MODEL_OUTPUT list of arguments may not
contain `virial', `particleVirial', or `hessian'. If it does, a
negative match is obtained and the routine returns KIM_STATUS_FAIL.
If the Model's MODEL_INPUT list of arguments contains `process_dEdr'
and the Test's MODEL_INPUT list of arguments does not contain
`process_dEdr', then (in memory) the routine adds `virial' and
`particleVirial' arguments, with the `optional' keyword, to the Model's
MODEL_OUTPUT list of arguments.
and `process_d2Edr2', then (in memory) the routine adds `hessian', with
the `optional' keyword, to the Model's MODEL_OUTPUT list of arguments.
For each non-optional argument in the Model's MODEL_INPUT list of
arguments, a corresponding entry must exist in the Test's MODEL_INPUT
list of arguments. If at least one such argument is missing from the
Test's list, a negative match is obtained and the routine returns
KIM_STATUS_FAIL.
For each argument in the Test's MODEL_INPUT list of arguments, a
corresponding entry (either "optional" or required) must exist in the
Model's MODEL_INPUT list of arguments. If all such arguments are
present, then a positive match is obtained. If at least one such
argument is missing from the Model's list, a negative match is obtained
Finally, all optional arguments in the Model's MODEL_INPUT list of
arguments which are not contained in the Test's MODEL_INPUT list of
arguments have their `compute' flag set to KIM_COMPUTE_FALSE.
(9) MODEL_OUTPUT matching: For each non-optional argument in the Model's
MODEL_OUTPUT list of arguments, a corresponding entry must exist in the
Test's MODEL_OUTPUT list of arguments. If at least one such argument
is missing from the Test's list, a negative match is obtained and the
For each argument in the Test's MODEL_OUTPUT list of arguments, a
Model's MODEL_OUTPUT list of arguments. If all such arguments are
For each argument in the Test's MODEL_OUTPUT list of arguments, the
argument's `compute' flag is set to KIM_COMPUTE_TRUE. If the `virial'
or `particleVirial' arguments were added to the Model's MODEL_OUTPUT
list of arguments in step 8 and any of these arguments are contained in
the Test's MODEL_OUTPUT list of arguments, then the `process_dEdr'
argument's `compute' flag is set to KIM_COMPUTE_TRUE. If the `hessian'
argument was added to the Model's MODEL_OUTPUT list of arguments in
step 8 and this argument is in the Test's MODEL_OUTPUT list of
arguments, then the `compute' flags of the `process_dEdr' and
`process_d2Edr2' arguments are set to KIM_COMPUTE_TRUE.
Arguments:
void *kimmdl
reference pointer to KIM_API_model object (in C++ style, the
definition will be (KIM_API_model **)).
char *testname
null terminated character string that defines Test name. The
routine prepends the Tests' directory string (defined by the Make
variable KIM_TESTS_DIR, which is specified in the file
Makefile.KIM_Config) to obtain the file location of the Test
descriptor (.kim) file.
char *modelname
null terminated character string that defines the Model name.
The routine uses this name to find the character string in memory
that contains the Model's descriptor (.kim) file. At compile
time the descriptor file is stored in the Model's binary library
file. Thus, it is necessary to perform a `make' of the
openkim-api package after editing a Model's .kim file.
