Hi LAMMPS users
When I try to use the command 'make serial' or 'make mpi' in the src folder of LAMMPS, I get the error the following error:
make[1]: Entering directory `/calculate/lammps/src/Obj_serial'
Makefile.package.settings:5: ../../lib/reax/Makefile.lammps: No such file or directory
Makefile.package.settings:7: ../../lib/poems/Makefile.lammps: No such file or directory
Makefile.package.settings:8: ../../lib/mscg/Makefile.lammps: No such file or directory
Makefile.package.settings:9: ../../lib/meam/Makefile.lammps: No such file or directory
../../lib/kim/Makefile.lammps:19: ../../lib/kim/Makefile.KIM_DIR: No such file or directory
../../lib/kim/Makefile.lammps:27: *** kim-api-build-config utility is not available. Something is wrong with your KIM API package setup. Stop.
make[1]: Leaving directory `/calculate/lammps/src/Obj_serial'
make: *** [serial] Error 2
and when I try the same in src/MAKE folder, I get the following:
make: *** No rule to make target `serial'. Stop.
I am following the steps as per the LAMMPS Documentation. Could someone kindly help me in this.?
Hi LAMMPS users
or directory
file or directory
or directory
or directory
file or directory
or directory
file or directory
or directory
or directory
file or directory
no, you did not. you installed a whole lot of packages which depend on
compiling/configuring auxiliary code in the lib folders, and the error
messages clear indicates, that you didn't do that.
please re-read the compilation instructions in the LAMMPS documentation,
but more thoroughly and with more care.
