Dear Colleagues,
I am happy to announce the release of kim-api-v1.7.0 available immediately at:
https://openkim.org/kim-api/
This release includes various bug fixes and improvements. In addition, two changes required the increment from 1.6.X to 1.7.0. First, a new api routine (KIM_API_get_kim_str_len()) has been added. Second, a new build dependency (the 'xxd' utility) has been introduced. This utility is available by default on most kim-api compatible machines.
The NEWS entry for this release is:
=== kim-api-v1.7.0 ======================================================
* Use 'xxd' utility for encapsulation of KIM descriptor files and param. files
* Added LINKSOPATH variable to build system for advanced system install options
* Added KIM_API_get_kim_str_len() routine
* Fix inconsistencies in ex_test_Ar_multiple_models
* remove build system dependency on 'ed' program
* Update 'make add-*' mechanism to use permanent url's for openkim.org items
* Fix bugs and minor improvements to build system
* Minor improvements to error messages
* Updates to documentation
Hi Ryan-
When updating to KIM 1.7.0, I’ve noticed the following error when making several EAM models:
Creating… intermediate file… parameterized-model.cpp.
Creating… parameterized-model.o.
parameterized-model.cpp: In function ‘int process_paramfiles(char*, int*)’:
parameterized-model.cpp:7287:31: error: ‘paramfile_001’ was not declared in this scope
parameterized-model.cpp:7289:35: error: ‘paramfile_001_len’ was not declared in this scope
make[1]: *** [parameterized-model.o] Error 1
rm parameterized-model.cpp
make: *** [EAM_Dynamo_Landa_Wynblatt_AlPb__MO_699137396381_001-all] Error 2
This happened for:
Model… EAM_Dynamo_Landa_Wynblatt_AlPb__MO_699137396381_001
Model… EAM_Dynamo_Mendelev_Asta_AlMg__MO_658278549784_001
Model… EAM_Dynamo_Mendelev_Srolovitz_AlFe__MO_577453891941_001
Model… EAM_Dynamo_PurjaPun_Mishin_NiAl__MO_751354403791_001
Model… EAM_Dynamo_Zope_Mishin_TiAl__MO_117656786760_001
I just wanted to give you a heads up. I’m currently working with an EAM model that did compile correctly.
-Shawn
http://s3.openkim.org/kim-api/kim-api-v1.7.0.tgz
Hi Sean,
Right you are!!! Thanks for the bug report. It tuned out to be an easy build system fix, once I tracked down the problem...
I've released v1.7.1 with the fix; It is available now for download.
Cheers,
Ryan
