kind request for advice- LAMMPS
I would deeply appreciate your advice of this question regarding LAMMPS usage:
I am working on metallic multilayered composites. The simulation box is a block with periodic BC all around and contains two metals in the form of two layers on top of each other filling the upper half and the lower half of the box with the interface normal along say the z-direction (i.e. one metal fills INF INF INF INF 0.0 0.5lz and the other INF INF INF INF 0.5lz lz)
When this structure is in equilibrium we know that each layer should have zero Szz stress (normal to the interface) and the over all structure should have zero net Sxx and Syy in the plane.
Based on my knowledge of LAMMPS, my first attempt was to use the iso 0 box/relax fix along with structure relaxation procedure (either using minimization and/or molecular dynamics) but this results in final Pxx, Pyy and Pzz which are way off zero.
This led me to start with the z-direction first to make sure at least the pressures are right in that direction using the fix box/relax in the z direction first which relaxing the structure. This fix does achieve an overall zero Pzz but NOT in each individual layer. I looked for the possibility of modifying the pressure compute to base it on a group that is made of one material at the time but it seems that the pressure compute has to be associated with group all. I also defined two groups based on the atom type and tried using those groups in the box/relax fix but that did not make a difference either.
Ideally, I would like to be able to adjust the upper bound of the box based on the pressure in the upper layer to achieve the zero stress condition and do the same for the other material.
thanks in advance for your kind support.
best
Firas
The compute pressure command and its pxx,pyy,pzz are global values
for the entire system. You can also monitor per-atom stress (pressure)
via compute stress/atom. You can sum the per-atom values over a group
of atoms via compute reduce, of bin it spatially via fix ave/chunk, if you
want to monitor the “pressure” in different layers.
Thanks Steve,
the challenge for me is how to take this monitored pressure value in the desired location and use it (instead of the global values) to control the simulation (dimensions of box in this case) in order to achieve a desired local stress (pressure) value.
thanks again
regards,
Firas
One idea is to make a loop in your input script.
Inside the loop run for N ~ 1000 steps and monitor
the pressure in the region (via stress/atom and compute reduce).
Then use that value to change the box dimension(s) via
change_box and some variable computation. Repeat.
