Axel,
below is the output for the original in.peptide (lammps-30Jul16/examples/peptide/in.peptide)
…/…/src/lmp_kokkos_cuda -k on g 1 -sf kk -in in.peptide
LAMMPS (30 Jul 2016)
KOKKOS mode is enabled (…/kokkos.cpp:38)
using 1 GPU(s)
Reading data file …
orthogonal box = (36.8402 41.0137 29.7681) to (64.2116 68.3851 57.1395)
reading atoms …
2004 atoms
reading velocities …
2004 velocities
scanning bonds …
4 = max bonds/atom
scanning angles …
13 = max angles/atom
scanning dihedrals …
30 = max dihedrals/atom
scanning impropers …
2 = max impropers/atom
reading bonds …
1365 bonds
reading angles …
786 angles
reading dihedrals …
207 dihedrals
reading impropers …
12 impropers
Finding 1-2 1-3 1-4 neighbors …
Special bond factors lj: 0 0 0
Special bond factors coul: 0 0 0
4 = max # of 1-2 neighbors
7 = max # of 1-3 neighbors
14 = max # of 1-4 neighbors
18 = max # of special neighbors
Finding SHAKE clusters …
19 = # of size 2 clusters
6 = # of size 3 clusters
3 = # of size 4 clusters
640 = # of frozen angles
84 atoms in group peptide
PPPM initialization …
WARNING: Using 12-bit tables for long-range coulomb (…/kspace.cpp:316)
G vector (1/distance) = 0.268725
grid = 15 15 15
stencil order = 5
estimated absolute RMS force accuracy = 0.0228209
estimated relative force accuracy = 6.87243e-05
using double precision FFTs
3d grid and FFT values/proc = 10648 3375
Neighbor list info …
1 neighbor list requests
update every 1 steps, delay 5 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 5 5 5
Setting up Verlet run …
Unit style : real
Current step : 0
Time step : 2
WARNING: Fixes cannot send data in Kokkos communication, switching to classic communication (…/comm_kokkos.cpp:365)
SHAKE stats (type/ave/delta) on step 0
4 1.111 1.44264e-05 36
6 0.996998 7.26967e-06 12
8 1.08 1.32536e-05 18
10 1.111 1.22749e-05 24
12 1.08 1.11767e-05 18
14 0.96 0 2
18 0.957206 4.37979e-05 3840
31 104.519 0.00396029
Memory usage per processor = 30.2199 Mbytes
---------------- Step 0 ----- CPU = 0.0000 (sec) ----------------
TotEng = -5237.4580 KinEng = 1134.9186 Temp = 282.1005
PotEng = -6372.3766 E_bond = 16.5572 E_angle = 36.3726
E_dihed = 15.5190 E_impro = 1.9426 E_vdwl = 692.8945
E_coul = 26772.2646 E_long = -33907.9271 Press = -837.0112
terminate called after throwing an instance of ‘std::runtime_error’
what(): Kokkos::Experimental::Impl::SharedAllocationRecord< Kokkos::CudaHostPinnedSpace , void >::get_record ERROR
Traceback functionality not available
Aborted
