Kolmogorov-Crespi
How can one use a (or the) “Registry-Dependent Interlayer Potential” from Kolmogrov/Crespi (PRL 85, 4727) in lammps?
best,
Mo
How can one use a (or the) "Registry-Dependent Interlayer Potential" from
http://lammps.sandia.gov/doc/Section_modify.html
Hey Mo,
if this is implemented in LAMMPS, maybe look in the documentation how to
use it. If not, you have to extend LAMMPS probably (documentation
again). Sorry!
Stephan.
I took a look at the paper. For two atoms in neighboring layers, it calculates their pi-bond overlap which depends on transverse distance. That requires defining a normal vector, which is quite problematic, because it is not really a local property. Hence there is “semi-local” energy associated with each pair of atoms that depends on the positions of atoms in two graphene patches, total count is 2*(1+3*(1+2)) = 20 atoms. Deriving and coding forces (which the authors probably avoided), is a non-trivial exercise, probably exceeding the most difficult parts of REBO.
Aidan
