[kspace_modify] gewald is not modified by the value I impose
I am using LAMMPS version May 2016.
My system is free of charges, but I want to use ewald for the long range interactions instead of tail correction.
My script goes like that:
pair_style lj/long/coul/long long off 14.72
pair_modify tail no
kspace_style ewald/disp 1.0e-3
kspace_modify gewald/disp 0.27
pair_modify tail no
and the output file:
EwaldDisp initialization ...
WARNING: Ewald/disp Newton solver failed, using old method to estimate
g_ewald (../ewald_disp.cpp:202)
  G vector = 0.102946
My question is WHY 0.27 is not used??
​because it hasn't been programmed (yet).
looking through the code in ewald_disp.cpp and pppm_disp.cpp shows that
kspace_modify gewald/disp will only have an effect on pppm/di​sp.
try setting gewald instead, as ewald/disp seems to use it throughout.
The problem is that I don’t have charges in the system so to use gewald.
I will try with pppm/disp and compare the results
