Thanks for quick reply. But why that happens only with the latest release of lammps? Several previous ones work fine with the same build/run settings. I just download and use make mpi.
Mike
i cannot tell from there. there must have been something that you did different for the 22Aug18 release. LAMMPS hasn’t changed anything related to how it interfaces to MPI in a very, very long time. perhaps you need to download and compile again under controlled circumstances. …or try the very latest version, the 15 November 2018 (release candidate) version.
Thanks. I managed to solve it by manual deletion of Obj_mpi folder. Before I changed compiler version because intel 11 does not compile the latest version of lammps and it looks like some object files were kept from old compiler.
Mike.
