lammps as a python library
Hi everyone,
I was wondering about lammps performance when used as a python library (apart from the obvious overhead). I know it can get through mpi tu use multiple processors, but can it use GPU or CUDA properly?
and what about the time cost of functions like lmp.extract_variable(name,group,flag)?
just to give you the idea of what I am doing, in a global sense, I need to do an automatic check for system thermalisation before getting the thermo values of the system, and I thought of python wrapping as the cleanest and easiest solution (I’m still kinda afraid of getting my hands on the c++ code :frowning: )
greetings
pablo
Hi everyone,
there is no principal problem. the python library is essentially the
lammps executable with the main() function removed and some
convenience functions in plain C added. those are also the interface
to python (via ctypes).
there may be a benefit to using the GPU package, since it doesn't have
the sophisticated host/gpu data transfer logic.
ok, great, i’ll try this way then, thanks
pablo
