Your post is violating multiple of the forum guidelines and thus you are making it very hard to provide any advice or assistance.
- your quoted input in your post is unreadable (have you looked at it? does it look like your input to you??). The guidelines explain how to properly quote from files.
- you are not providing information about which LAMMPS version you are using, what platform you are running on and what your command line is
- when reporting errors or potential bugs, it is usually required to provide a minimal(!) but complete(!!) input deck that allows to reproduce the problem quickly. Ideal is often a case where you can reproduce the issue by modifying one of the LAMMPS examples, then you only need to provide the modified input and it is guaranteed that the system is small enough for debugging.
Please edit your post accordingly.
